 Post subject: Tosh notebook < Fujitsu HDD Dont Want to Play Together
PostPosted: June 11th, 2007, 6:07
Im new here, so first Hello and thanks for a great site!
I have a Toshiba notebook, Satellite 5205 (old now at 3 years, best feature swappable second hdd). Want to replace drive 0 with a new Fujitsu MHT2060AH.
Strange thing is that the drive is not seen by Tosh. I have 2 other drives of the same type, and get the same result. Testing with an sata adapter on a desktop = no problems.
I can't get into the Toshiba BIOS, and even if I could I understand that "some older notebooks" burn the drive list into some cmos-like chip. So Im a nOOb - hay, I write user code -- as far as I know the only difference between my computer and a coffee maker is one has a keyboard!! :roll:
Any ideas? The drive I am replacing is a Toshiba MK6022GAX badly damaged in a fall... actually down a flight of stairs.
Thanks - CodeToad
 Post subject:
PostPosted: June 11th, 2007, 10:11
Hmm, check the master/slave/CS jumper.
The four little pins next to the main 44-way connector.
Some notebooks require drives to be set as Master, whereas some want CS.
 Post subject:
PostPosted: June 12th, 2007, 13:49
Yes , just like PCIMAGE say it is a master/ slave setting.
This notebook has two ide channel. Ther can be other hdd in salect bay.
Ty jumers setting it will help you.
Users browsing this forum: No registered users and 57 guests
