 Post subject: up graded to win xp pro and lost all sound?? HELP
PostPosted: June 21st, 2007, 3:47
:oops: :oops: :oops: hi lost all sound after up grade what can i do HELP ( 9hp site no help )
 Post subject:
PostPosted: June 21st, 2007, 5:46
go to device manager , and check if you sound drivers are installed
 Post subject:
PostPosted: June 21st, 2007, 6:06
Some Realtek sound chips have a problem with XP SP2 and latest updates.
There is a patch on MS website.
But, better check your device manager first. Like Steve suggests.
 Post subject:
PostPosted: June 21st, 2007, 15:02
If You Could Actually Check The Sound Chip On The Board And Then Try To Find The Drivers From The Manufacturer Site For Sound I Am Sure you will Solve Your Problem
 Post subject:
PostPosted: June 21st, 2007, 17:14
thanks but no disk got lost
 Post subject:
PostPosted: June 21st, 2007, 17:17
i was told my the person that installed the win xp program that maybe i could talk to hp but i went to web site and nothing also maybe theres a web site that i can get them for free
 Post subject:
PostPosted: June 21st, 2007, 17:21
its a hp 864 media center edition and its got a maxtor 4a160jo does that help you guys any also drivers are not installed under multi media audio
 Post subject:
PostPosted: June 21st, 2007, 17:36
http://h10025.www1.hp.com/ewfrf/wc/soft ... 96&lang=en for HP864
http://h10025.www1.hp.com/ewfrf/wc/soft ... 99&lang=en For HP864n
 Post subject:
PostPosted: June 21st, 2007, 18:16
:shock: :shock: hi steve thanks alot but one thing what do i download on this page . im a newby or lame at computers im afraid to do the wrong thing sorry may i ask for further directions :) :D
 Post subject:
PostPosted: June 21st, 2007, 18:40
first thing I would do is go back to device manager , right click any device that isn't installed , then click "Update Driver " if that doesn't fix it , then download and install : http://h10025.www1.hp.com/ewfrf/wc/soft ... 28&lang=en
Drivers can sometimes be a pain in the ass.. it helps if you have the install disk .. also since this is an HP computer look to see if you have a hidden partition on your hard drive ( this is the re-install partition) if you can see it ( as D drive ) the drivers should also be there
 Post subject:
PostPosted: June 21st, 2007, 19:16
steve thanks again listen under other devices in the device manager its showwing negative under the other deviceswhich consists of multi media audio controler ,multi media controller, and pci input device does that help you thanks alot.. jaime
 Post subject:
PostPosted: June 21st, 2007, 19:21
steve its me again im pretty sure i ve done that down load yesterday and nothing yet,, thanks again i look foward to hearing from you
 Post subject:
PostPosted: June 21st, 2007, 19:27
when i try to play a c d a message comes up sayng that there may not be a sound device ?does this info help any one steve?
 Post subject:
PostPosted: June 21st, 2007, 19:28
ok Let's try this
Assuming that your upgrade to XP Pro is from a legit copy . make sure you have SP2 installed
also go to Windows Update and and get all updates available ..
After you have all the updates.
go to the device manager , and every device that has a "?" or "!" or is in Other devices , right click , and click "Uninstall"
If it says you need to reboot , click "no" until you have them All uninstalled .. Then Reboot the computer .. Make sure you are connected to the internet then windows will look for the drivers when you reboot. if it asks for where , be sure to check the windows update box ..
Hope this helps
 Post subject:
PostPosted: June 21st, 2007, 23:49
cant believe how hard this has been for ive spent over 15 hour in 3 days triying to pin point this $%#@ out but yes theres a ? and a ! on ecery thing under other devices and it says that criver is no enabled what driver ? sound driver ??? where can i find the right one i remember there was a speaker icon on the right lower side of desk top that i would click and there came like a master mixing console! thet is now gone ever since the upgrade to xp pro thank you again steve any further help would greatly help
 Post subject:
PostPosted: June 22nd, 2007, 2:14
you just have to keep looking till you find the driver for each one that is in other devices .and yes it is probably the sound driver..
 Post subject:
PostPosted: June 22nd, 2007, 23:43
im sorry but were can i look? for sound drivers :(
 Post subject:
PostPosted: June 25th, 2007, 0:25
Hi download sisoft sandra, install and run click on sound devices and it will tell you exactly what chip it uses for your audio. Do a search on driverguide or HP website and download & run the driver setup and you should be done. Just in case go into your bios (usually F1 or delete when booting and check that your onboard audio is still enabled just in case a setting was changed accidentally. This will prevent driver installation also.
I think ST is a sub company of Lucas
 Post subject:
PostPosted: July 1st, 2007, 21:11
yes amigo but the kinda charge? i was looking for more of a charity group help or at least at at alower gguerantee price near by me housebut gracias amigo agaian
