 Post subject: Hitachi firmware upgrade - problem
PostPosted: June 20th, 2007, 3:21
I have Hitachi TravelStar IC25N060ATMR04-0 drive
I download and burn this: http://hddguru.com/content/en/software/ ... le-CD-ISO/
but this doesn`t work propertly :(
I haven`t ThinkPad :(
What can I do?
Maybe some trick or alternative soft?
Sorry for my english :oops:
 Post subject:
PostPosted: June 20th, 2007, 3:47
I assume your poblem is that th drive is limited to 8Gb?
Could be HPA cut (use MHDD to fix back to max LBA), or F/W corruption.
If it's F/w corruption, then I don't think the f/w "update" program will work. It only updates, not fixes. I bet it will only update a handfull of modules, not the full f/w.
 Post subject:
PostPosted: June 20th, 2007, 4:01
No.
I want to erase drive with DFT software.
Now program stopped when chech SMART status :(
I read @ another forum, firmware upgrade can (but not must) erase SMART attributes and i want to chech it myself :)
Drive is very slow and have much bad sectors - i have nothing to loose :)
Other erasers (like WDCLEAD, MHDD, Victoria etc.) not erase drive like i want :)
Only i want is upgrade firmware in my drive. Other help is not necessary.
 Post subject:
PostPosted: June 20th, 2007, 4:19
Well, you'll never get it to erase until you get it recognised as the full 60Gb.
IMHO you have more problems than a few bad sectors.
The SMART has failed for a reason, coupled with the fact it's only seen as 60Gb, it doesn't look good.
Have you actually tried to reset the HPA with MHDD?
 Post subject:
PostPosted: June 20th, 2007, 5:15
Something reminds me another topic when a guy was just needed a maxtor firmware upgrade and nothing else... :lol:
 Post subject:
PostPosted: June 20th, 2007, 6:45
 Post subject:
PostPosted: June 20th, 2007, 7:52
When i told, drive is NOT 60GB?
Drive is 60GB and i have problem only with SMART status.
I want to reset attributs for erase by DFT.
Then i think, what can i do :)
 Post subject:
PostPosted: June 20th, 2007, 10:55
U need special tools for access vendor tracks, like ace lab products, the another way its make your own tools
Best Regards
 Post subject:
PostPosted: June 20th, 2007, 13:32
Look at Hitachi tool. It says current capacity = 8063.51Mb which is ~ 8Gb
Trust me, from the evidence you give you have more problems than a simple reset smart and erase will fix ;-)
Maybe you can try "HDD Repair 2.0" to reset the SMART, but I doubt it will do you any good.
I know it seems a shame to waste a 60Gb drive, but unless you have lots of spare time on your hands, then bin it!
Good luck
Sean
 Post subject:
PostPosted: June 20th, 2007, 14:06
hdd repair 2.0 does not work on laptop drives
 Post subject:
PostPosted: June 20th, 2007, 14:19
Tool see only 8GB because drive is not detect on BIOS!
I connect HDD to old i440LX mobo with P3 333MHz (32GB limit)
When i connect it to Promise Ultra100 TX2 controller, drive is normal detect as 60GB.
I repeat: I want only to reset smart attributes and i want to upgrade firmware.
I haven`t hardware PC3000, only emulator for DOS, but it`s don`t support this drive :(
Some ideas?
 Post subject:
PostPosted: June 21st, 2007, 1:14
Spildit wrote:
Try to upgrade your HDD Firmware using a PC that can detect the full capacity of the drive !!!!!
I patch my BIOS with BIOS Patchee, but i still can`t upgrade the firmware :(
BIOS detect correctly drive!
Spildit wrote:
If that's your own goal try to use the test provided by drive fitness test. It should move G-List to P-List and fix anny S.M.A.R.T. Problem. Don't upgrade firmware.
Unfortunately, when i launch quick or advanced test in DFT, program stopped with error: SMART failed...
Spildit wrote:
Go buy original products and software. Pirated software is not good to anyone. If you can't buy the software go buy another drive.
Try to use free or less expensive alternatives to PC-3000.
It wasn`t nice :(
Maybe you can tell me, what can i use?
How software can i use?
I`m not a professional service and i can`t buy full PC3000 carb by 1k Euro or something :(
Mayby someone knows method to completely clear G-List and/or P-List?
 Post subject:
PostPosted: June 26th, 2007, 2:02
So... thanx fo help :(
Bye
Users browsing this forum: Google [Bot] and 77 guests
