 Post subject: R/W channel heat
PostPosted: July 23rd, 2007, 16:36
I have many WD and IBM drives they have very common problem R/W channel on these drives heat really much is there anything i can do for fixing these problem other than changing the pcb .
Thanks in advance .
 Post subject: Re: R/W channel heat
PostPosted: July 24th, 2007, 3:17
Rameez ,
Use a Cabinet Design That Blows Air Directly To The Drives .Like http://www.coolermaster.com .It Will Be Much Cooler Then You Can Expect .We Mostly Overlook This When Making PC In India At Least
PostPosted: July 25th, 2007, 14:21
Banned User
hi
whats this cabinet design? any chemical or hardware
PostPosted: July 26th, 2007, 5:55
How Can a Cabinet Design Be Chemical ? .Yes It Is Hardware ,Its Just that There is a 120mm Fan That Blows Airflow Directly Across The PCB And The MHA .There Are Other Things Other Then HDD Repairing And DR Also, You Please Stress The Top Grey Matter Beyond HDD Repairs And DR It Helps ? ,Instead of Chatting With Me And Saying I Am Just Trying To Become Famous In HDDguru Forums And Provoking Me For No Reason And Then Running Away By Saying Bye And Not Chatting ...... :evil:
PostPosted: July 26th, 2007, 12:49
tried that already any other thing u could suggest , I have seen in new wd drives there is a heat sink on the R/W channel if i apply that will it work .
Amarbir ,
leave personal matters here .
PostPosted: July 26th, 2007, 13:10
Yes Rameez ,
You Could Use a Heat Sink That is Installed In The South Bridge Of Motherboards ,If That Fits .I Remember Selling ASUS Nvidia Boards Which Stinking Hot South Bridges And A Heatsink did The Trick
PostPosted: July 26th, 2007, 15:20
rameez - Just a hint, make sure you get some good heat transfer compound aswell - this can make or break the effectiveness of a heatsink. You could also try the little heatsinks/combos off mini-itx boards - they're designed to do some work in a limited space.
scegs
PostPosted: July 26th, 2007, 15:40
Banned User
the all things u said, are useless and meaningless here, no one will understand abt it, if u know anything other than hdd then its not a good thing for us and u, its ur matter, u again trying to show u a good person.
PostPosted: July 28th, 2007, 12:36
cool down bro .
i use silicon grease anyother compound u could suggest .
PostPosted: July 28th, 2007, 23:16
Chill down fellows..........
Amarbir and Arfaizy.........
It seems now, that the topic is getting rather heated then Rameez's WD and IBM's R/W channels. :roll:
And the worst thing is that I am not supposed to find any Heat Sink or Silicon Grease to chill up THIS heat. :lol:
BTW Rameez, One can insist on Silicon Grease after making sure the presence of Zinc Oxide in it.
PostPosted: July 29th, 2007, 10:49
Sorry Guys,
He Was Just Provoking Me .Any Way I Am Not To discuss That If Someone Thinks I don'nt Know anything No Issue .And Rameez Coolermaster HAs Heatsing Compound Also .We Sell It In India For Rs :125 a syringe .
PostPosted: July 29th, 2007, 16:03
Heatsink compound (THERMAL INTERFACE PASTE) can either be silicon(e) or non-silicon(e) based.... silicone has tendency to separate and migrate; though for temporary jobs - who really cares!
To remove compound either use WD-40, Isopropyl Alcohol, fairy liquid, xylene based cleaners...
scegs
PostPosted: July 30th, 2007, 1:57
Banned User
Amarbir wrote:
Sorry Guys,
do not discuss personal matters here, its not ur court, its a forum, if u need to discuss personal matters then come at messenger
thx
PostPosted: July 30th, 2007, 3:20
Stop Bugging others. Stop blaming each other.
:evil:
DF :)
www.datatracksystem.net
PostPosted: July 30th, 2007, 14:16
i have a hard time finding heat sink for this R/W channel can i make them , if yes what metal should i use .
PostPosted: July 31st, 2007, 3:26
Hi Rameez,
Just Take The Heat Sink From Old Rotten Motherboards Cut It And Use It .
Users browsing this forum: Bing [Bot] and 68 guests
