 Post subject: Problem with IC25N040ATMR04-0
PostPosted: August 13th, 2007, 8:35
I have a Hitachi Travelstar Model IC25N040ATMR04-0 that I was using as an extrenal usb hard disk drive. It was working perfectly fine till today. When I plug it into the USB, it gives the red light first and then it turns to light green. The task bar shows that a USB is connected the system but My computer doesn't show the drive.
Please help me and tell me how can I recover my data?
Hasan Saleem
 Post subject: Re: Problem with IC25N040ATMR04-0
PostPosted: August 13th, 2007, 9:15
First of all, remove the hard drive from the box and connect it directly to a computer and see the results.
PostPosted: August 13th, 2007, 22:05
I have tried that. I have tried changign the cables. I have also tried it on 6 different computers but it is not working
Is there any software or something that can help me?
PostPosted: August 14th, 2007, 3:25
What happens when you connect the drive to a computer? Do you ear any strange sound?
PostPosted: August 14th, 2007, 4:12
Listen to the drive. Is it spinning? Power On/Off and listen close :idea:
A man is as old as he feels, and a woman as old as she looks
PostPosted: August 14th, 2007, 6:05
When I connect it to the computer, the disc goes light green straight away when it should be blinking red (as my other discs do)
The taskbar shows a little green arrow that means something is connected to the system but when I open My computer, I don't see any disks at all there..
I have checked the sounds on this disk and others (working fine) - They have the same sound. It spins inside
PostPosted: August 14th, 2007, 7:37
That means the disk is detecting in BIOS use MHDD and do a scan on the drive and post results here that way we could help u better .
PostPosted: August 14th, 2007, 7:44
Rameez! I don't know how to do that. Can you please give me your phone in PM? I will call you
PostPosted: August 14th, 2007, 14:07
Check if it spins up or not first of all.
PostPosted: August 14th, 2007, 14:30
It definitely spins as I have written earlier.
PostPosted: August 14th, 2007, 14:38
OK.
Then you can check surface in MHDD to see if it's readable at all.
PostPosted: August 14th, 2007, 14:43
Starling wrote:
OK.
How to do that?
PostPosted: August 14th, 2007, 14:56
Read the documentation, download MHDD and do that.
If your time is so expensive that you can't afford to follow the link and read the manual then it's probably better to send it directly to DR company and they'll do it for you.
PostPosted: August 14th, 2007, 15:01
I would do that right now and see if it works... But software's would work only if the disk is accessible
It shows as if it is connected to the system but then there is no drive..
PostPosted: August 14th, 2007, 15:36
I have downloaded it but I can't do that. No idea how to play with it
PostPosted: August 14th, 2007, 15:50
Links:
MHDD FAQ
MHDD Documentation
PostPosted: August 15th, 2007, 6:20
You could also try Victoria which runs through Windows, no need to remove hard disk from the USB caddy either.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 173 guests
