 Post subject: assistance required in deciphering Terminal log
PostPosted: September 1st, 2007, 21:07
Hello Guys,
I am having a problem with a Baracuda 7200.7. I am having super manny bad sectors and can't get access to the data. I really don't have any experience with Seagate drives. Any help is appreciated.
Here is the return from the Terminal (I can get T prompt but can't switch to F).
              Spin Ready
8.04  12-19-05 10:47  4096k x 16 buffer
(P)(H)SATA Reset
Interface task reset
4096k x 16 buffer detected
PUMA2 - 1_Disk    0.03  12-19-05 10:45
Head Mask FFFF - Switch to full int.
              Spin Ready
(P)(H)SATA Reset
AT Er 00 Nwt Er 37 RdWr 00036.01.0391
ATA St 80 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot:  0000394b  ff  0000394b.e.c89 0005  0000 0000 0000
DiskAccess ReadSector EC=43 at 000036.01.0391
SCAN Error
AT Er 00 Nwt Er 37 RdWr 0eafc.01.01cf
DiskAccess ReadSector EC=43 at 00eafc.01.01cf
SCAN Error
I am having some dificulties reading the log, I downloaded the seagate diagnostic command document but am still a bit clueless. Any additional information on Terminal commands would be great as wel.
I asume this means Heads are OK, is this correct?
 Post subject: Re: assistance required in deciphering Terminal log
PostPosted: September 1st, 2007, 23:03
I think it is HDA problem
PostPosted: September 1st, 2007, 23:12
its BSY, or u get DRDY DSC?
If u get DRDY DSC; u can try to check heads
Best Regards
PostPosted: September 2nd, 2007, 12:12
Thanks for the quick replies.
In PC 3000 I don't get any registers, only times out with HD ID readding timeout when using ATA Mode. In Terminal mode I get a output mentioned in the above post.
SCAN Error
I think I should be able to check heads from T:> (but I don't know the command).
PostPosted: September 2nd, 2007, 21:51
you can try press CTRL+Z
it should be able to go to T command
Users browsing this forum: Google [Bot], melvin and 59 guests
