I've been reading a lot of the posts on this forum lately but cannot find a solution to my problem:
I have a Maxtor DiamondMax 10 that got burned (don't really remember how). Here's an image:
When I turn it on it will spin but I kindda clicks(beeps) every second or so.
I figured "just replace the board". I ordered the most similar board from the softcom website, replaced it and now the drive spins up ok, no beeps, but will not read of write from the disk. There are some differences between the boards but as I read there's suppose to be compatible. In my system the drive is seen as a Maxtor 6B300R0 and in System Management the capacity is 278GB. My original drive is 250GB. I figure that the firmware doesn't match and go to a place to switch the burned component with the one on the board I received. Same thing the drive spins up but will not read and I still read it as 6B300R0.
Tried a demo of GetDataBack which helped me in the past but I only get IO errors.
Tried HDD Capacity Restore but it says hdd is damaged in some way and it cannot fix it.
After a lot more reading I suspected the preamp in the head unit but the new board doesn't get burned when I connect it so I'm not so sure. My next step is to get a multimeter and try to test the preamp following a guide on this forum but in the meanwhile is there something I can do ?
