 Post subject: Seagate 1T bytes terminal connection
PostPosted: May 15th, 2008, 2:33
Hi guys
Does anyone know the terminal connection for Seagate ST31000340AS? I tried using the 4 pins (next to SATA data cable) but the terminal shows nothing.
 Post subject: Re: Seagate 1T bytes terminal connection
PostPosted: May 15th, 2008, 3:29
I would also like to know how (if possible) to connect to a 500Gb 7200.11.
TIA
Sean
PostPosted: May 15th, 2008, 7:20
me too. seagate change terminal access to 72.11
can not connect using standard sata jumper port
Спасибо
СУТИОНО / АПИНГ
PostPosted: May 16th, 2008, 22:04
anyone have succeeded in connecting to terminal?
PostPosted: May 16th, 2008, 23:38
I am also joining you.
DF :)
DF :)
www.datatracksystem.net
PostPosted: May 17th, 2008, 13:06
This is new family disks. Terminal connection pinout is the same as before. I'll give you a small hint: Everything is faster now :)
PostPosted: May 18th, 2008, 18:33
How fast? It was 9600 in the past IIRC. What's up now? 38k4?
PostPosted: May 19th, 2008, 0:24
There's not too many variations, U can try... :)
PostPosted: September 23rd, 2008, 9:23
Well I have purchased a 7200.11 for some R&D :O) After looking at info related to these drives I am very excited by the control you can have over the diag port . Looks even easier than before!!!!!!!!!!!!!!!!
Well done Seagate for making a lovely terminal for us gimps
PostPosted: September 23rd, 2008, 10:47
Just to be sure.. I don't have any of these drives yet ;o)
PostPosted: September 23rd, 2008, 12:07
guru wrote:
After looking at info related to these drives I am very excited by the control you can have over the diag port. Looks even easier than before!!!!!!!!!!!!!!!!
What are you smoking in cosmos? :)
PostPosted: September 23rd, 2008, 12:20
Pure Jamaican :O)
PostPosted: September 23rd, 2008, 14:01
Hi ,
I Have the Same With Me ,will Like To Experiment And Tell You What and How It will work ,
PostPosted: September 24th, 2008, 4:26
Amarbir.. What have you found?
