Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: How to identify a Disk
PostPosted: May 20th, 2008, 19:39
Open the drive in a clean room and make sure the platters and filter are free from defects before you spend any money. Why do you suspect a faulty pcb?
PostPosted: May 20th, 2008, 19:45
I did check the platters after seeing it had been opened. They are clean and in good shape.
I suspect the pcb mainly because the heads move back and forth across the platter, but the drive is not recognized by bios. Drive spins up fine.
I was hoping to pick up a whole disk if I could get enough info, that way if it is the head, I would have a set of those as well as a matching pcb.
http://www.ancilesecurity.com
PostPosted: May 20th, 2008, 19:47
Also, forgot to mention the drive stopped working after power spike & blackout. That mainly led me to suspect electronics (PCB)
post44366.html?hilit=dcm%20top%20bottom#p44366
DCM 101
PostPosted: May 20th, 2008, 19:49
Also useful, but again how do I find out MY dcm?
I don't mean to frustrate you, I appreciate your expertise and your time. This is all good info. But if I can't properly identify my drive, I can't get good working parts for it.
PostPosted: May 20th, 2008, 19:56
http://harddrive-repair.com/hard-drive-parts.html
PostPosted: May 20th, 2008, 20:09
that's exactly what i needed......thanks thatdellguy
PostPosted: May 21st, 2008, 16:45
Preamp is damaged IMHO after the power surge.
PostPosted: May 21st, 2008, 17:25
If that's the case, how do i determine replacement heads/preamp with having the DCM of the disk?
Any ideas?
PostPosted: May 21st, 2008, 20:07
I agree with pepe, but you really need special tools to verify the preamp circuit or your going to make it worse. :shock:
PostPosted: May 21st, 2008, 20:36
OK but in the absence of special tools......replacing the pcb and the preamp/head should work no?
Overkill, maybe, but if it fixes the drive, the client is willing to pay for it.
Users browsing this forum: No registered users and 62 guests
