 Post subject: ST3500630A Error: ERR App Code incompatible SFL code
PostPosted: June 4th, 2008, 10:43
After a head swap on a Seagate 7200.10 ST3500630A i get the following in the terminal:
4096k x 32 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
Buzz HM SFI
ERR Read App Code
Then i try to read the code using the terminal commands, and this gives:
F>R
Code - A6 Track 15CC4.0.238 Sns FFF
F>j
I tried with different boards, but i always get the same SFL error.
Anybody who can help ?
Thanks in advance,
Dobre
Murphy was an optimist
 Post subject: Re: ST3500630A Error: ERR App Code incompatible SFL code
PostPosted: June 4th, 2008, 11:03
Application code has read errors or PCB is not original
PostPosted: June 4th, 2008, 21:48
ERR Read App Code from my experience is incompatible preamp
PostPosted: June 5th, 2008, 3:54
I used an identical drive, same partnr, same site code.
Only difference is patient has FW 3.AAD and donor 3.AAE but that should not be the cause.
Dobre
PostPosted: June 5th, 2008, 12:43
Dobre
Did you write original ROM into donor's PCB?
PostPosted: June 5th, 2008, 13:17
Hi Doomer,
I use the original PCB, since that has no problems.
However, this disk has been with another company before, and there is the writing "SPARE 160" on it. So i guess they changed the pcb.
I'm contacting my client so he can ask for the original pcb.
Dobre
PostPosted: October 4th, 2008, 4:48
4096k x 32 DRAM
Buzz HM SFI
ERR Read App Code
F>R
F>j
Thanks in advance,
Dobre
sway bios to new boards
maybe you sway wrong head to bad-disk
PostPosted: October 1st, 2013, 6:19
suntom wrote:
4096k x 32 DRAM
Buzz HM SFI
ERR Read App Code
F>R
F>j
Thanks in advance,
Dobre
4096k x 32 DRAM
Buzz HM SFI
ERR Read App Code
F>R
F>j
Thanks in advance,
Dobre
I have same output in Terminal after issueing R and j, produces same output like yours.
PCB is original.
How to resolve this?
I have same T
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
Users browsing this forum: No registered users and 98 guests
