 Post subject: PCB Maxtor-Diamondmax10-Sata-250Gb-Sn:6L250SO-Pcb:r4gla
PostPosted: August 23rd, 2008, 13:57
Help my pcb died!! A puff of smoke from a chip, i tried to swap with another chip but doesn't start! So only the same pcb will save my Gbs!
There's my hd, i'm italian. See you!
http://img239.imageshack.us/my.php?image=hd4sz6.jpg
http://img239.imageshack.us/my.php?image=hd3da9.jpg
http://img143.imageshack.us/my.php?image=hd2sf1.jpg
http://img143.imageshack.us/my.php?image=hd1qi1.jpg
 Post subject: Re: PCB Maxtor-Diamondmax10-Sata-250Gb-Sn:6L250SO-Pcb:r4gla
PostPosted: August 23rd, 2008, 14:26
hi,
you already replaced the chip and no response from the drive. did you check the fuses/safety diodes of the pcb? maybe one ore more of them are gone.
Greetings,
Stephan
PostPosted: August 23rd, 2008, 16:01
oh well... gosh! diodes.. it's a miracle i've found a person able to swap that chip, i think i'll not have other miracles to understand in that sea of chips a fused diode!
sorry.. i'm a donkey about electronic parts... pcb too!
i just need that damned pcb
Thanks for support..
PostPosted: August 23rd, 2008, 16:04
The simplest way is to get a new / used ENTIRE drive only for the PCB hoping the damage has not gone further
( ITALIAN TRANSLATION : fai prima a trovare un altro HDD uguale e usi solo la scheda - sperando che il guasto si sia fermato li')
PostPosted: August 24th, 2008, 14:23
I have compatible pcb for the drive PM for details .
PostPosted: August 25th, 2008, 8:35
i also tried with a r3gla pcb... but it's not compatible.. sorry rameez
PostPosted: August 25th, 2008, 14:55
I have taken a look to your images.
I think about the damage, your preamp is dead as well. :(
You need to check this, before, probing another pcb.
Regards,
Janos
PostPosted: August 26th, 2008, 7:27
preamp? well i don't know where the preamp is in my hd.
but.. engines seem to be ok because while using the swapped pcb
the sound at start was tzzzz TZZZZ tzzzz TZZZZ but bios didn't detect the hd!
and it has NOT fried the swapped pcb!
so i think ( i hope ) i have fried only the pcb!
i just think the r3gla was not the right pcb.
See you!
PostPosted: August 26th, 2008, 19:40
if it is tzzzzz tzzzz tzzzzz-ing, probably the spindle bearing is seized, causing the original motor controller to burn...
bad news. :(
PostPosted: August 27th, 2008, 16:01
yes that sound was like Tzzz but the pcb was not the right pcb in fact the other pcb has less legs contacting on hd slot than the original pcb!i mean the original has x legs and the hd surface has x legs while the other pcb has x-3 legs.. i just hope!
PostPosted: August 27th, 2008, 16:03
Did you checked, it is really spin?
If not, you have a bigger problem....
Janos
PostPosted: August 28th, 2008, 16:51
well... yes.. i hope it was the spinning sound.
it was like the hd find a bad cluster..
but.. i'm not absolutely sure!
i just have to open my drive!
Users browsing this forum: Google [Bot], michael chiklis and 82 guests
