 Post subject: samsung sp0411 N all modules OK Where is Problem?
PostPosted: July 16th, 2007, 11:38
Hi I am operating samsung hard disk and read SA but unable to identify problem area .Data Extractor is not working for this hdd.
Where could be the problem?
Family selected: PANGO
Model................................... : SP0411N
Technological ID
Data waiting timeout
Techno passport not loaded
Zone allocated table not loaded!
SA SPT.................................. : 928
Modules table used by default
Read ROM via terminal
Into folder............................. : <HDD Profile>\Data\ROM
No HDD response
Reading modules
Into folder............................. : <HDD Profile>\Data\Modules
00 FSI.................................. : OK
02 FIT.................................. : OK
04 MLIST................................ : OK
05 SRVTBL............................... : OK
64 SKTIME3.............................. : OK
61 MODELID.............................. : OK
06 CONFIG............................... : OK
07 SNTBL................................ : OK
08 BISPT................................ : OK
09 BRSLT................................ : OK
0A CRITERIA............................. : OK
0B FINALTST............................. : OK
0C ARCOTBL.............................. : OK
0D GEO_TBL.............................. : OK
0E VLISTHDR............................. : OK
0F VLIST................................ : OK
10 SLISTHDR............................. : OK
11 SLIST................................ : OK
12 TLIST................................ : OK
13 ALIST................................ : OK
15 SETMAX............................... : OK
16 SECURITY............................. : OK
17 SRVTBL2.............................. : OK
18 ARCOTBL2............................. : OK
14 TMPRTR............................... : OK
19 OVERLAY.............................. : OK
5A VL40CODE............................. : OK
5B VL40CHN.............................. : OK
29 DLIST................................ : OK
41 SPESB0............................... : OK
42 SPESB1............................... : OK
43 SPESB2............................... : OK
44 SPESB3............................... : OK
45 SPESB4............................... : OK
1A HDAF_RPT............................. : OK
1B HD_DLIST............................. : OK
1C LATCHFRC............................. : OK
1D RCOSCRPT............................. : OK
1F ERRTRK............................... : OK
20 ERRZN................................ : OK
21 ERRDRV............................... : OK
22 SRTDATA.............................. : OK
23 SRTSRVO.............................. : OK
24 SCN_GRAY............................. : OK
25 PARAM................................ : OK
26 WKHEAD............................... : OK
27 TSTPI................................ : OK
28 MRTUNEMT............................. : OK
1E BTIME................................ : OK
53 MRRTABLE............................. : OK
54 NPV_RSLT............................. : OK
56 ARCOTBL3............................. : OK
62 BPITEST.............................. : OK
63 ARCOTBL4............................. : OK
2A GEO_00............................... : OK
2B TST_ZH............................... : OK
2C GEO_ZH............................... : OK
47 CAPSEL............................... : OK
48 CURBPI............................... : OK
49 AZLCSM............................... : OK
4A AZL_CSM0............................. : OK
4B AZL_CSM1............................. : OK
4C AZL_CSM2............................. : OK
4D AZL_CSM3............................. : OK
4E AZL_CSM4............................. : OK
4F AZL_CSM5............................. : OK
50 AZL_CSM6............................. : OK
2D AZLBPI............................... : OK
2E AZL_BPI0............................. : OK
2F AZL_BPI1............................. : OK
30 AZL_BPI2............................. : OK
31 AZL_BPI3............................. : OK
32 AZL_BPI4............................. : OK
33 AZL_BPI5............................. : OK
34 AZL_BPI6............................. : OK
52 INSTABHD............................. : OK
57 ATE.................................. : OK
58 WII.................................. : OK
59 TPTP................................. : OK
51 SPSTW................................ : OK
36 RCO_LOG.............................. : OK
5C TSTPI2............................... : OK
5D BPITEST2............................. : OK
5E ATE2................................. : OK
5F TPTP2................................ : OK
60 BRSLT2............................... : OK
66 BER2................................. : OK
37 SMART................................ : Read sector error (c:11,h:0,s: 2) (UNC)
38 SMRT_LOG............................. : Read sector error (c:11,h:0,s: 3) (UNC)
39 SMRT_TST............................. : OK
3A SMRT_HLG............................. : OK
3B BIAS_SHK............................. : OK
3D ELOG................................. : OK
46 BIMODAL.............................. : OK
3F SV_TRACE............................. : Read sector error (c:20,h:0,s: 1) (AMN)
40 PES_LOG.............................. : Read sector error (c:20,h:0,s: 11) (AMN)
3E IPC_DBG.............................. : Read sector error (c:20,h:0,s: 302) (AMN)
5C PMP.................................. : OK
Test completed
 Post subject: Re: samsung sp0411 N all modules OK Where is Problem?
PostPosted: July 16th, 2007, 13:07
Technological ID
some problem is there
df
DF :)
www.datatracksystem.net
PostPosted: July 17th, 2007, 7:41
Thank you Darkforce
As i am from india these drives are common and problem must be in f/w . Thanks a lot for your quick reply
Chipsang
PostPosted: July 17th, 2007, 9:52
I am also from India. You are which city
DF
DF :)
PostPosted: September 13th, 2008, 4:59
I have samsung sv4002h Hard disk drive.
Not coming readiness in the original controller. I have same type of donor controller. Using donor controller it gives readiness, but at the soft reset it give busy with drd and dsc.
and gives Technological ID - Data waiting time out.
Data waiting timeout error comes in the every module read.
I have tried of 3-4 same type card. but same errors come.
Data is important.
Thanks,
amit shah
PostPosted: September 13th, 2008, 7:08
@thinclient, check the ROM content. Also, make sure for head working. Have you checked terminal ?
PostPosted: September 16th, 2008, 4:56
I have changed the Rom Ic at491024 from original to donor controller.
Now Terminal shows
UCalib done
Eng>
soft reset is ok
Hard reset is ok
but rom read or module read not possible every time hdd response time out. no hdde readiness type messages are coming.
thanks,
amit shah
PostPosted: September 18th, 2008, 18:05
I just had the same drive, SP0411N, with exactly the same symptoms as the OP.
Drive came DRDY after maybe 30 seconds, and all modules OK. No user data though.
Swapped the platter into new chassis (with good head, as the head was underneath the platter, so easier to swap the platter).
Now the drive is imaging well, nice and fast.
So, must have been a weak head.
Sean
PostPosted: September 19th, 2008, 6:15
Hi Sean Congrats
Its good you reached to the problem.So it was heads .This will help everyone in future.
Chipsang
PostPosted: September 21st, 2008, 1:42
very intelligent pcimage
Users browsing this forum: No registered users and 275 guests
