 Post subject: Fujitsu MHV password
PostPosted: September 14th, 2008, 3:10
i have a fujitsu MHV hard disk,it has been set password,how to use PC3000-UDMA clera the passwrod? on adapter pc-2 card how to set jump ? and,how to use PC-FUJ.SATA?
hard disk interface:IDE
thanks!
 Post subject: Re: Fujitsu MHV password
PostPosted: September 14th, 2008, 7:46
UDMA can't unlock some drives in that Fujitsu family...
I have one myself and have been talking to ACE about this and they didn't have any solution of it yet.
But you can try: No jumpers on the pc-card, test menu/Service information/work with SA/Security subsystem/Password erasing
Regards/ Bosse
http://www.rescue-it.se
PostPosted: September 14th, 2008, 14:22
Ask Atola, ACE, Salvdata and some others if they support (or will support) disable security on ALL MHV models, would be interesting to know.
PostPosted: September 15th, 2008, 6:26
clear password,i had been try it,this opreation can't remove the password
who can help me?!! :oops:
PostPosted: September 16th, 2008, 10:41
Copy module SU from a donor (unlocked) to the locked drive. Should do the trick.
PostPosted: September 16th, 2008, 12:42
Hi msurgeon,
Did you read what mr_spokk wrote ?
PostPosted: September 16th, 2008, 12:49
Some MHV drives can be unlocked with re-writing SU, some cannot
It depends of firmware revision
PostPosted: September 16th, 2008, 14:31
coffeebean wrote:
Hi msurgeon,
Yes. I've successfully unlocked MHV2080AH with this method. I can't vouch for all MHV models.
PostPosted: September 16th, 2008, 18:49
Hi msurgeon,
As mr_spokk wrote some MHVs can allow typical read of SU and SM and quite a few MHVs do not.
PostPosted: September 17th, 2008, 8:54
thanks again
PostPosted: September 17th, 2008, 8:55
I will try it
