Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: It appears as though I broke a connector pin....
PostPosted: September 27th, 2008, 6:08
K0NPHL1C7 wrote:
From what I gather, you somehow think maybe something on the topside is fried... Here's a pic of "the other side" of my PCB...
As I said, the ONLY thing wrong as far as I can tell is the pin being pushed back. I'm not retarded, if a chip was fried out I would have said so...
Sorry, no, i don't say that because want to see burned chips.
I am thinked about bad soldering, and additionals caused by bad soldering....
The only interesting is in your meassage is the clicking noise.
Regards,
Janos
PostPosted: September 27th, 2008, 9:14
Regards,
Janos
Oh right right right. Ya the soldering job isn't the best, but I was pretty carefull not to make any connections that were't supposed to be there. As far as I can gather there isn't any visable damage done by the soldering.
As for the "clicking noise" - I made a mistake in posting that. What I head was the electric "trigger" on my HDD Enclosure trying to power the drive on. When i moved the drive in to a regular desktop PC, there was no clik at all. In fact it sounded as good as the day I bought it one year ago.
So from what I'm reading, even if I do swap out the PCB for one with the same firmware, I'll need to swap out a chip or two on the PCB? I dont know if I'd be able to do that...
PostPosted: September 28th, 2008, 16:00
U can get an exact match as well .
PostPosted: September 28th, 2008, 22:05
So in other words, the exact match that you have, should not need to be modified at all? (assuming replacing the PCB solves my problem)
PostPosted: September 30th, 2008, 14:25
Yes .
PostPosted: October 6th, 2008, 11:21
It's the other 8-leg chip...can't remember what is written on it right now..
Data Recovery Ireland
PostPosted: October 9th, 2008, 18:11
K0NPHL1C7 wrote:
I have a Seagate Barracuda 7200.8 300gb with lots of stuff that I never backed up (tisk tisk). Anyway a connector pin broke off, I tried soldering it but it still will not read. I do hear a clicking noise, but no spinnning.
As far as I can tell the only thing wrong would be the pin. I assume I need to replace the PCB, but I'm having a tough time finding a replacment. Any suggestions???
Hi ,
You Can change the Whole connector ,If You Wanna Do That Say it I will Teach you Right Here .
PostPosted: October 9th, 2008, 21:35
I beleive it was tricky question
This PCB have only ROM and no NVRAM chip (Some Seagates' PCBs have even no ROM chip - on such PCBs ROM is inside MCU)
Users browsing this forum: No registered users and 296 guests
