 Post subject: WD1200JB-22GVC0 SE
PostPosted: October 24th, 2008, 3:03
HELLO THERE
I AM NEW IN THIS SITE. HOPE YOU CAN HELP. APPRECIATE IT.
I HAVE A WD1200JB-22GVC0 SE. VERY HARD TO FIND.
THID HDD IS BURNED ON THE MBO. LEFT SIDE OF MBO. THE SQUARE ONE WITH 16
FEET EACH SIDE. SEE PICTURE.
WE TRIED TO FIND SIMILIAR DRIVE. NO SUCCESS.
A GUY IN THE USA SAID IT'S SIMILIAR TO WD1200JB-00GVC0. WE BOUGHT SUCH DRIVE, SWAPPEED
THE MBO. CLICKING. NOT WORKING.
DOES ANYBODY HAVE A GOOD SUGGESTION, AND/OR SIMILIAR WD1200JB-22GVC0.
DCM CODE=HSCACTJCA.
P/N OF MBO 2061-701265-200
TKS VERY MUCH FOR YOUR HELP
EPHRAIM
 Post subject: Re: WD1200JB-22GVC0 SE
PostPosted: October 24th, 2008, 3:12
You have to swap U12 too.
If that is not working probably heads or preamplifier are defective.
Best regards,
Dobre
Murphy was an optimist
PostPosted: October 24th, 2008, 8:50
TKS FOR YOUR REPLY DOBRE.
COUPLE OF QUESTIONS:
WHAT IS THE U12 ?
A SIMILIAR BOARD WILL NOT HELP?
PostPosted: October 24th, 2008, 8:52
WHAT IS THE U12 ?
The U12 is a serial EE, wich contains the drive configuration for this assembly.
Similar board have a minimal chance to match these.
Regards,
Janos
PostPosted: October 24th, 2008, 8:59
TKS Janos.
WHERE IS THIS CHIP (?) LOCATED ON THE DRIVE?
TKS
PostPosted: October 24th, 2008, 9:36
take a look at the pcb in the space between the cpu (wd70c26 .. the biggest chip) and the spindle four contacts connector, you will find a 8 pins chip (yours seem to be a ST 25P10VP) with a "U12" written on pcb ... that's it!
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: October 24th, 2008, 10:09
TKS Janos and/or IRS FOR THE ANSWERS.
YOUR INFO WAS EXCELLENT.
THE LAST QUESTION FOR NOW IS ALL OF THIS MUST BE DONE WITH A SIMILAR
MBO. RIGHT?
IF THE ANSWERS IS YES THAN I HAVE STILL THE PROBLEM WITH DONATOR MBO.
IF ANYONE KNOWS PLS LET US KNOW. WE SEARCHED THE WHOLW WEB, INCLUDING EBAY. FOUND NITHING.
TKS A LOT AGAIN
EPHRAIM
PostPosted: October 24th, 2008, 10:18
You dont have to match the 22GVC0 or DCM code.
Dobre
PostPosted: October 24th, 2008, 14:49
I have a similar PCB if intrested PM me .
