 Post subject: WD3200AAJB PWB 2060-701494-001. PCB damaged
PostPosted: November 12th, 2008, 8:25
This disk will not now spin up and is not recognised by the bios
I have seen earlier posts about this drive, but looking at the PCB, the important U12 chip is not there, just the label.
Does anyone have a PCB and if so, how do get the U12 data across when there is no U12 chip?
Thanks,
 Post subject: Re: WD3200AAJB PWB 2060-701494-001. PCB damaged
PostPosted: November 12th, 2008, 9:05
Ouch!
Yours has ROM info embedded into the Marvell chip :-(
Probably easier to change the Smooth Chip, and hope that's all that's blown.
Either way, you need pro help.
PostPosted: November 13th, 2008, 7:24
Thanks for the reply. If I were to find an identical board, with the ROM embedded in the CPU, I could not just substitute that board? You mean that the ROM is unique to my drive and somehow I must get it onto the new logic board?
PostPosted: November 13th, 2008, 7:47
Due to the damahe to the smooth chip I wouldn't be surprised if theres more internal damage. Pre amp might be dead to.
PostPosted: November 13th, 2008, 7:52
Is there a way I can check? I have a multimeter. Sounds like I'm on a loser anyway because of that embedded ROM.
PostPosted: November 13th, 2008, 8:03
This is the model number PWB 2060-701494-001 REV A
The only other numbers on there are 2B94V-0 and E222034
PostPosted: November 14th, 2008, 2:41
Embedded rom = no user solution even with good 'skill'... I have a solution, but most probably your data is not worth a standard dr price for this drive/problem.
PostPosted: August 19th, 2011, 15:47
BlackST, can you continue this? I have same problem as above. There is pictures on my drive i desperately want/need. I am a dummy who didnt back them up :roll:
ANY help would be awesome!
Dave
PostPosted: August 19th, 2011, 15:57
You have to refer to the nearest professional.
Where are you located ?
PostPosted: August 19th, 2011, 16:08
New Jersey, United States. Thanks for your quick response on this too.
PostPosted: August 19th, 2011, 16:23
I'll PM you later (just let me contact some people).
PostPosted: August 19th, 2011, 17:00
Thank you
Users browsing this forum: Google [Bot] and 124 guests
cron
