 Post subject: ST3500830AS won't spin up OK, recording attached
PostPosted: November 28th, 2008, 10:51
The 12V line shows about 1A except a dip to 0 as it attempts a restart. The 5V line about 250mA. According to the client the disk was taken from a Mac, attempted to plug it into a PC, then back to the MAC. The disk was looked at by another recovery firm but is unopened.
I have little experience with Seagate, but it sounds like a stuck spindle to me. Looking at what happened to the disk though I am doubting the PCB, but it "looks" fine.
Thanks! :mrgreen:
Recording11.zip [523.71 KiB]
Downloaded 397 times
 Post subject: Re: ST3500830AS won't spin up OK, recording attached
PostPosted: November 28th, 2008, 11:00
Seized Spindle. Do a platter swap. Data should be fine.
Yes sounds like spindel stuck, jammed or could be a head sticktion too, need´s to check inside
PostPosted: November 28th, 2008, 11:30
Sounds like spindle to me too.
Very common on these.
Sean
PostPosted: November 28th, 2008, 12:13
thanks for the help guys, will take a peak if/when client accepts quote ;)
PostPosted: November 28th, 2008, 12:33
If your not familiar with this fault and the platter swap procedure for this disk with spacers, then my advice would be to outsource, or practice on some dead donors.
PostPosted: November 28th, 2008, 12:55
If the client does not accept quote, practice on it anyway :twisted:
Only kidding.
PostPosted: November 28th, 2008, 13:23
well, i am half hoping its sticktion... if it is really a stuck spindle I will practice like crazy first. outsourse will not be an alternative for this client "as his data is not worth THAT much" ehehehhe (ever heard that before?)
PostPosted: November 28th, 2008, 13:48
Where are u based?
Users browsing this forum: Google [Bot] and 59 guests
