 Post subject: Generic Hitachi question
PostPosted: September 2nd, 2008, 15:21
I've got a bad 400 GB Hitachi Deskstar that won't spin up. The motor ohms fine and the PCB is not the problem.
Before I open this bad boy up (10 heads / 5 platters) I would like to know if:
1. Bearing seizures are common on this model;
2. What kind of success people are having with head/platter transplants;
3. If the bearing can be loosened successfully without having to do step 2
Thx
http://www.datasaversllc.com
 Post subject: Re: Generic Hitachi question
PostPosted: September 2nd, 2008, 15:47
Was the drive dropped? I bet yes... Then the axis is bent and PS is last resort.
PostPosted: September 2nd, 2008, 15:54
Thanks, BlackST.
The client swore the drive wasn't mishandled or abused . . . .
PostPosted: September 2nd, 2008, 16:00
Of course they do, a seized bearing is not so uncommon, anyway.
PostPosted: December 16th, 2008, 14:46
Hello, this was crazy, just had a hitachi desktar 400gb that
has som issues, i think its been dropped on the side also.
but want is PS? PCB swap?
PostPosted: December 16th, 2008, 15:19
If was dropped could be damaged the FDB , its a big problem u cannot fix it by self if u get data back u know the solution
PostPosted: December 16th, 2008, 15:28
Thx
I open hdd and look heads and platters to take a decision where to make. This and my opinion
Good luck!!
Нет ничего невозможного
Users browsing this forum: Google [Bot] and 145 guests
