Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: Hitachi Travelstar HTS541010G9AT00 PCB Failure
PostPosted: July 31st, 2008, 16:04
I have a Hitachi Travelstar 100 GB HTS541010G9AT00 That appears to have a PCB issue. When connected with the original PCB, the drive doesn't spin. I purchased a pcb from the same model hard drive with a mfg date of 1 month prior to the original. With this installed, the drive spins, but still isn't recognized. Is there another step that I ma missing or any thing that needs to be swapped from the original pcb to the new one?
 Post subject: Re: Hitachi Travelstar HTS541010G9AT00 PCB Failure
PostPosted: July 31st, 2008, 21:43
You need to transplant the ROM from the old board to the new.
http://www.datasaversllc.com
PostPosted: August 1st, 2008, 7:53
Yes, agree with jono, copy/move the nvram from the original.
Nvram is unique for this family.
Also, make sure the 1st two lines on the sticker on the PCB match.
PostPosted: August 1st, 2008, 9:54
The first two lines on the sticker do match. What is the best way to desolder the nvram? I was having a togh time with that last night with a pencil iron/solder wick combo
PostPosted: August 2nd, 2008, 13:31
Hot air station and Soldering iron would do your work , if u are not good at soldering find someone with good soldering/desoldering skills .
PostPosted: January 24th, 2009, 16:00
I have the same issue with my HTS541010G9AT00. Did you resolve yours? I'm about to purchase the PCB but feel nervous b/c I've never done anything like this. Do you have instructions or diagrams on the repair for a total newbie?
PostPosted: January 24th, 2009, 16:14
Spoon feeding ?
PostPosted: January 26th, 2009, 6:18
google is newbie's bestfriend.
PostPosted: January 29th, 2009, 19:04
Searched Google for a couple of hours but didn't find much. There was a site that mentioned replacing the 8 PIN EEPROM IC which made it confusing.
I've taken the HDD out of it's casing but haven't removed the PCB yet. Is the NVRAM an obvious piece on the PCB?
PostPosted: January 30th, 2009, 6:17
It is to me.
PostPosted: January 30th, 2009, 7:11
And to me ;-)
It IS a very tiny chip , and easily bugger-upable!
PostPosted: January 30th, 2009, 7:20
pcimage wrote:
And to me ;-)
Is bugger-upable a real word??? :lol: :?:
PostPosted: January 30th, 2009, 7:21
hddguy wrote:
pcimage wrote:
And to me ;-)
It must be. I've read it on a forum somewhere. :lol:
PostPosted: January 30th, 2009, 8:00
wasn't that a name of a film? :oops:
PostPosted: January 30th, 2009, 8:42
use a periphrase : EASY TO SCREW UP. :D
PostPosted: January 30th, 2009, 11:07
In my little world, it's a real word!
You all knew what I meant! ;-)
PostPosted: February 7th, 2009, 20:11
Thanks for the help so far. I'm going to try repairing this HDD on my own. I'm still on the hunt for parts and finding out it's not that easy.
Anybody have luck finding vendors who sell PC boards? I've looked around but only found an unreliable ebay seller. If anybody can help me identify the NVRAM chip I would greatly appreciate it.
PostPosted: February 7th, 2009, 21:04
I can supply you a PCB no problem, but it ain't gonna work!
The NVRAM on board is virtually unique, as it points to addresses on the SA etc..
PostPosted: February 7th, 2009, 23:50
Ditto.
PostPosted: February 8th, 2009, 13:19
Hi to all,
I have this Hitachi Travelstar HTS424040M9AT00 - a 40GB drive, I have nearly the same problem " Drive doesnt even spin when connected to the computer through the portable casing "
The cable has some loose connection, I bought two USB ports and soldered it, Mostly I messed up connecting the wrong way to the USB pins i.e. at both the ends, and gave the power, the drive remains quiet, its dead :? . I expected the drive to be detected but it failed to do so. Where might have the things gone wrong, I changed the casing, nothing happened, still the drive behaves the same, what might have gone wrong pls help me !!! :roll:
Thanks in advance
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 64 guests
