 Post subject: Western digital WD800JD head
PostPosted: February 18th, 2009, 1:46
Does anyone head compatibility in WD800JD sabre 58 (unicorn) is compatible with sabre 53 ?
Patient WD800JD sabre58 (Unicorn is SATA) and the donor is WD800JB?
According to ACElab developer matching DCM is a myth, it is a conflicting to what i have experienced and seen on this forum that DCM is important when doing head exchange.
Thank you for any feedbacks.
 Post subject: Re: Western digital WD800JD head
PostPosted: February 18th, 2009, 4:34
TerraNova:
I have to agree with some of statement from ACE
DCM is a myth, for some models but it's a guide for us to deal with some other models.
Maybe we can change experience through PM.
My Forum
PostPosted: February 18th, 2009, 5:32
I have seen DCM in SA which does not match DCM on drive label ... Strange but true
PostPosted: February 18th, 2009, 5:36
Unicorn and Sabre head is not interchangeable ? please confirm, thanks
PostPosted: February 18th, 2009, 10:10
and that's a real one
PostPosted: February 18th, 2009, 10:13
In order to confirm it somebody supposed to try to replace heads. I guess nobody tried
PostPosted: February 18th, 2009, 15:15
TerraNova,
WD are very capricious drives and there are many requirements for a Head Swap. Actually main requirements is a same family, same head map and same factory (country-developer). But sometimes it's not enough and donor heads don't work... :cry:
I can suggest you to find Unicorn donor, it saves your money and time.
About DCM it's really myth. I have never use it when I look for a donor.
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: February 18th, 2009, 21:48
thank you guys, MYTH busted! :D
PostPosted: February 21st, 2009, 17:27
I did head swap of different families in WD but they were pretty close in date, and PCB was similar too. I cannot remember the families unfortunately...
Users browsing this forum: No registered users and 55 guests
