 Post subject: E BUX C735 component on hddrive ST3320820AS
PostPosted: February 23rd, 2009, 14:39
Hello
I not the first one that has put his HD on a wrong voltage
and yes, it is also a seagate ST3320820AS 320 gb
but i have detected the burned component.
it is a black thing markt
E
BUX
C735
Does anyone know what this componet is, and how i can find it?
Many thanks
Josuls
 Post subject: Re: E BUX C735 component on hddrive ST3320820AS
PostPosted: February 23rd, 2009, 16:41
Wheres your picture?
PostPosted: February 23rd, 2009, 17:32
How many hundreds do you want ?
PostPosted: February 24th, 2009, 0:40
Sounds like a TVS.
PostPosted: February 24th, 2009, 4:45
I am from the Netherlands, an I will be happy with one.
and what is at TVS?
Josuls
PostPosted: February 24th, 2009, 4:56
Just remove the burned component and the drive will be OK. :lol:
Don't change the voltage anymore...
PostPosted: February 24th, 2009, 19:41
There is a website called www.letmegooglethatforyou.com. I am finding that we need something like that except with the forum's search function.
PostPosted: February 24th, 2009, 19:45
Tooooo funny...have to bookmark that one...
PostPosted: February 25th, 2009, 3:31
It is a diode.
Pninja
PostPosted: February 25th, 2009, 7:09
Thnx to all. a specially to mr_spock and BGman
I removed it and it works. Verry nice
Tnkx to drccsc I will google that way :)
After i removed that little thing i was suprissed that it works. I begin to think to remove my computer too :lol: :roll:
PostPosted: March 20th, 2009, 12:33
Hi josuls, I burned my segate HD too, it is also a ST3320820AS. In my case I found a little piece, the E BUX C735, how can I know this piece is the one that is burned??? Is it ok to just remove it??
If I get a new exact HD, could I change the controller card?
Thanks a lot.
Fernando.
PostPosted: March 20th, 2009, 12:40
No one can say for sure. You'll have to check whether the TVS is the reason - it would be shorted then. If not, you have another problem.
The drive can be run without the TVS, but most people doing so simple don't know what they are doing: they are running the hard disk without the very component that has previously saved the drives life. If the drive is to be re-used, the TVS should always be replaced AND the reason for its failure removed (bad power supply for example).
Users browsing this forum: Google [Bot] and 297 guests
