 Post subject: SAMSUNG SP4004H
PostPosted: March 24th, 2009, 15:29
Hi to all,
Need some help in this disk.
The disk came to me but dont spin, i change the pcb with a looking pcb and connect the disk, i can see that disk now spin, but i just can have DRD, in terminal appear this:
U H:  +00000
H:  +00001
H:  +00002
H:  +00003
H:  +00000
H:  +00001
In there anyhting i can do this pcb "remove chip" for have the disk working?
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: SAMSUNG SP4004H
PostPosted: March 24th, 2009, 15:34
PM :mrgreen:
Нет ничего невозможного
PostPosted: March 24th, 2009, 15:37
I am not "fully" familiar with samsungs....Dont get to many of them.
I cant read the number on the chip, but i think the 8 legged chip in the top left above the RAM may need to be transferred.
PostPosted: March 24th, 2009, 15:44
No, the U3 is the good choice. ;)
Additionally, better to measure the preamp before trying another pcb!
Janos
PostPosted: March 24th, 2009, 18:49
Completely wrong : the code is in part in the SID chip , the main code is in the AT49F1024. There is no SPI external rom to be transferred.
Problem #1 : do the PCB belong to the same drive and code revision (SP4004 / xxxxx-yy) ? This PCB, with different main code, works on many drives.
Check the revision of the main code. If have no tools, the ROM should be read/reprogrammed externally (desolder it).
When I see the screws have been removed, I assume that some "Wile E. Coyote" engineering has done by end user or other so-called "expert".
Problem #2 : has the MC been poked or any FW 'fix' attempted ?
Note that main code AND overlays (on platter) must match for the drive to get ready AND eventually accept command !
Just in case , you know I can do EVERYTHING with Samsungs... ring me on IM.
PostPosted: March 24th, 2009, 19:00
I vote for checking the preamp.
the original PCB was bad, preamp could have been exposed to high voltages as well.
PostPosted: March 25th, 2009, 2:15
No Pepe. The log would be VERY DIFFERENT !! There are many little problems that lead to 'dead' Samsungs with no PS related issues. I have addressed the problem via MSN.
PostPosted: March 25th, 2009, 3:13
Ok, I haven't have this model for recovery for ages now, so I must admit I don't remember the exact logs, but such log on a PALO drive (for example) makes me suspect preamp problem.
checking preamp doesn't hurt anyway on such cases, just to be sure.
PostPosted: March 25th, 2009, 7:55
If it was the preamp or completely not working headstack or head physically disconnected, at least you had a Gray Err. (uh... haven't seen the complete log BTW !) and it should click badly then turn off almost immediately.
PostPosted: March 25th, 2009, 8:10
Thanks ,
I have scanner the disk with the pcb.
Since i dont have the same disk, i found a similiar looking PCB to try.
in this case it looks like the code revision is not the same.
ZeBong
" Россия еще раз"
PostPosted: March 25th, 2009, 8:42
The PCBs are somwhat different, but the problem IS definitely the main code.
Users browsing this forum: No registered users and 72 guests
