Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate 7200.11 BSY error 12CC4 message
PostPosted: April 7th, 2009, 17:16
Good luck then :D
P.S. it is fixable.
PostPosted: April 7th, 2009, 21:41
So you are giving me hints? :twisted:
I found a guy with the same problem. He also got his drive at Fry's.
The firmware on those drives really is is different? :?
PostPosted: April 8th, 2009, 0:35
Mike31T wrote:
Reasons to keep it
1)RMAs are usually painfully annoying
that's interesting experience
Mike31T wrote:
2)I can't erase the drive if I can't access it
and why do you need to erase it?
Mike31T wrote:
3)There is bank account and credit card info on that drive
there is a bank account number on each check you sign - have you been robbed every time you signed a check?
And I guess every time you paying with you credit card in grocery store you probably looking for pirates around
Mike31T wrote:
4)I don't want some asshole laughing at my pr0n
Are there funny clowns? Almost 90% of all recovery drives from personal users have some stuff. It looks like HDD manufatures should sell drives with complete set of videos and pictures to save users's time and money :mrgreen:
Mike31T wrote:
5)I like fixing things
You had complete step by step guide and you failed. Beleive me "fixing things" is not your good side
PostPosted: April 8th, 2009, 1:27
@ Doomer : reply of the week award.
@ Mike : I think that a pro near you can fix your disk AND erase everything (SS) for much less than 100$. It's different from data recovery, you need only the drive, right?
PostPosted: April 8th, 2009, 2:37
That would actually be helpful. I'll be willing to take a long drive if necessary. Could you please pm me with the contact information?
PostPosted: April 8th, 2009, 2:44
I am at the opposite corner of the world : search this forum for a pro near you and ask him. It's easier. You only need a firmware fix AND the drive recertified. P.s. Don't expect to have it done in front of you or while you wait. It will take about 2 days.
PostPosted: April 8th, 2009, 2:58
I think you should just put a hammer through it and buy another drive. Save you time, petrol (GAS) and money. They are cheap enough.
PostPosted: April 8th, 2009, 4:10
Uh.. no, currently there is a strong request for FIXING hard drives at a reasonable price. This can be one. Obviously is not a good idea to drive 200 KM. to do it. NOTE : in this case for me FIXING means NO FIXING THE FW ONLY. Means FIXING AND DESTROY ALL DATA IN IT. Forget having a 2-300$ job done for 20-30. :wink:
PostPosted: February 15th, 2010, 17:01
Sorry to reopen a very old thread, but...
I'm also running into this "Unknown Diag Cmd" ... 12CC4 message. I have two 'affected' seagate 7200.11 drives, both purchased at Fry's Electronics (the only other mention of this "Unknown Diag Cmd" error online says the drive was from Fry's).
I am able to spin the drive up and down using the Serial -> TTL adapter, but when I issue the SMART reset, it gives me the 12CC4 message.
I'm wondering if there's a different approach to fixing this: replace the entire board with one from a near-identical drive... Is the firmware ON the board? Or is it inside the case? If it's on the board, is it "married" to the drive inside? Maybe screwing a board with new firmware onto the drive would allow it to magically work? Maybe a long shot...
Thanks for your help.
PS, for background see "The Solution for Seagate 7200.11 HDDs - MSFN Forums" via google (the forum is down at the moment) or other google results with a similar name.
PostPosted: February 15th, 2010, 22:57
no
PostPosted: February 16th, 2010, 21:04
Here are repair procedures for Seagate 7200.11 drives:
http://sites.google.com/site/seagatefix/
http://www.msfn.org/board/index.php?showtopic=128807
Tutorial with photos:
http://www.overclock.net/hard-drives-st ... -pics.html
Pinout of Nokia CA-42 cable's Pop-port connector (use pins 6,7,8):
http://pinouts.ru/CellularPhones-Nokia/ ... nout.shtml
See the following technical bulletin:
http://atulchitnis.net/files/seagate.pdf
Seagate were at one time offering free data recovery services to those customers whose drives were affected by the bug. This may still be the case.
PostPosted: February 16th, 2010, 21:14
You might notice that this person has already tried that and it didn't work
PostPosted: February 16th, 2010, 22:02
Daisy Woo wrote:
...... because it is an OEM drive, but mostly, I just want to fix a hard drive.
And there you have it, it is not a seagate as it has OEM firmware, so the fix will not work on OEM drives - only Seagate. So you will need to send it to a pro (+data) or return it to OEM for replacement (-data)
Dwoooo
At my facility we have done the same procedure on hundreds of OEM drives.
Users browsing this forum: Google [Bot], pepe and 120 guests
