 Post subject: I need loader and modules drive maxtor n40p
PostPosted: May 30th, 2009, 12:39
Hi all,
Please I need *.ldr and modules a drive maxtor modelo 6E040LO NAR61590 SERIAL E1K
Thanks for your help
 Post subject: Re: I need loader and modules drive maxtor n40p
PostPosted: May 30th, 2009, 15:01
More precision, please. And for what platform?
PostPosted: May 30th, 2009, 15:59
For PC3000 or Salvation?
PostPosted: May 31st, 2009, 12:03
Friends is for Pc3000
PostPosted: May 31st, 2009, 12:04
With salvation data hddoctor for maxtor this is the problem
I have a drive maxtor n40p with problem in modules, the drive is detected with N40P. I load boot and load the file .res when I run head reset the drive passt of busy to ready and next i execute head postioning the drive show in status error. When I dont execute the head postioning and load the .res I check the fwdefect scan and I scan the key mods and all shows error, I upload the key mods with error and the process is ok, but rescan the keys mods and return error.
Note: I haf all the firmware of a same donor.
I need recover all the data of the drive. The drive is maxtor 6E040LO NAR 61590 SN E1K.
thanks for your help
PostPosted: May 31st, 2009, 12:24
You are doing something wrong. Did you ask SD SUPPORT? Note : a N40p is the ABC OF DATA RECOVERY.
P.s. Buy Ace PC3000 ASAP.
PostPosted: May 31st, 2009, 12:29
BlackST, I also have pc3000 you have the .ldr and modules of this drive?
PostPosted: May 31st, 2009, 12:41
Post complete model and identifier , i.e. 6e040L0xxyyy and material mix. Pcb I am quite sure is B8FEA or similar. Search in the files section of this forum - pc3000 subsection.
PostPosted: May 31st, 2009, 13:29
while u get all mod error, u have wrong steps...
u have to Load the RAM also, ignore Head Positioning. I am sure u will get the correct steps...
if u get the Error status again, u have bad head either bad sa.
but this drives have tend to bad head.
inform the next...
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: May 31st, 2009, 13:32
+ ADDING
If you cant still access the SA, try a HOT SWAP.
__________
THANK YOU
SHAHI
PostPosted: October 14th, 2014, 3:47
Hi there!
I also need a loader and modules for a very similar drive:
Maxtor Diamondmax Plus 8
Date:01NOV2003
Code:NAR61590
Model:6E040L0510614
PCB:B8FEA
AAA
SN:E1KWA6ZE
K,M,B,A
Singapore
I have Atola Insight, and China HDD MRT Pro
Thanks for any help!
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 90 guests
