 Post subject: maxtor 80gig need firmware
PostPosted: June 25th, 2009, 6:14
hi,
i am using salvation doctor and need firmware badly for
6Y080L043651
sn-Y2BQXLZE
code- YAR41BW0
 Post subject: Re: maxtor 80gig need firmware
PostPosted: June 25th, 2009, 8:28
Hi this model's firmware is present on the original firmware package provided with the hd doctor, if you don't have it you can download the .rar file from SD forum
bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: June 26th, 2009, 5:16
i did try but it doesnt seem to be working... when i try loading rom.. the drive clicks for a long white then gives an error....
PostPosted: June 26th, 2009, 8:25
Oh...
1) bad method
2) bad loader/resource
3) the drive has head problems so any loader will make it click forever.
4) the drive has SA problems so the clicking.
Do you know how to work with CALYPSO drives ?
PostPosted: June 26th, 2009, 8:50
Sometimes even loader from same good working drive can make calypso click
on same good working drive.
You need to answer BlackST's question, first.
PostPosted: June 26th, 2009, 9:19
no i dont...
PostPosted: June 26th, 2009, 9:44
It is impossible : if the loader is built EXACTLY, it should work ALWAYS. If this happens you have... er... wrong software or there's something wrong out there :D
PostPosted: June 27th, 2009, 3:48
k so under the boot management tab
i load a boot,then i load rom then load all mods... everything comes to ok... when i click hdd resset it starts clicking....
any ideas? someone mentioned the heads might be gone
PostPosted: June 27th, 2009, 4:37
Check read channel, then proceed.
PostPosted: June 28th, 2009, 19:25
read channel?
PostPosted: June 29th, 2009, 0:54
Yes. :(
PostPosted: June 30th, 2009, 8:15
Hi, on sd products you can try head positioning or track positioning after loading rom and all mods + hdd reset.
For my experience if a loader doesen't work or you got the wrong one (different checksum) or you have other problems - heads or SA (damaged, bad sectors ulist ko ...) - may be you can try a C boot loader and check if you can read SA.
Bye
Luca
PostPosted: June 30th, 2009, 15:59
thanks irs..i'll try that :)
Users browsing this forum: No registered users and 171 guests
