 Post subject: issues wth WD10EACS Kermit
PostPosted: July 1st, 2009, 19:46
Hi all
i am having an issue with the above drive.
Drie initially would not spin up correctly, it would start spinning, stop, do this about 3 times and then stop spinning all together.
I swapped board with a donor drive, drive now spins and becomes ready and remains spinning correctly.
however drive will not id, and shows oMb
tried hot swap method and same thing happens.
i have included a ful report of the drive and am wondering if anyone can share their thoughts on this drive.
the patient drive is a model no WD10EACS - 00D6B1 25 novemebr 2008
i have used a donor board from WD10EACS-00D6B0 25 september 2008
for soe reason these 2 drives have different board on them
i have done a heads test and this all seems to be ok as you will see in the report.
if a head swap is required will these 2 drives be compataible. manufacture date is 2 months apart.
Can anyone tell me the difference between the B1 and B0 revision
attached is the log
thank you
report.doc [151.5 KiB]
Downloaded 357 times
 Post subject: Re: issues wth WD10EACS Kermit
PostPosted: July 1st, 2009, 20:57
what happens when you update the rom on the new pcb?
Zero Alpha: zeroalpha.com.au
PostPosted: July 1st, 2009, 21:29
hi Zero ALpha
with rom update drive spins up normally, will not show id, still shows 0 MB
the log supplied is from the patient drive with donor pcb
thx for reply
PostPosted: July 1st, 2009, 22:02
The drive has not initialised. Check the head map.
PostPosted: August 10th, 2009, 5:01
want to sell the board if you have finished with it?..... my turn....... :) :?
PostPosted: November 26th, 2009, 4:03
crecomp wrote:
Hi all
attached is the log
thank you
Hi Crecomp,
did you solve the problem of your HDD?
I have the same problem with the same HDD family (WD10EACS-00L5B1).
please let me know if you have any advice to deal with the problem.
Thank you
Users browsing this forum: No registered users and 298 guests
