 Post subject: pleasehelp me with my WD5000AAJS
PostPosted: June 12th, 2009, 14:30
I have a WD5000AAJS external 500 GB drive that it needs a new board. It spins for short time when I hook it up to my PC but it turns off afterwads, I took it to some data recovery places and they found that I need to replace the PCB which is burned. Please help to find a PCB similar to what I have.
Spec:
Western Digital: 500 GB WD Caviar SE
Model WD5000AAJS-32vfa0
Date: 10 Jan 2008
PCB Model Number:
2061-701477-100 04P
YOUSIF
 Post subject: Re: pleasehelp me with my WD5000AAJS
PostPosted: June 12th, 2009, 15:42
PCB swap on this model not helps, because have configuration chip or embeded ROM in MCU.
If you need the data, i suggest to find a pro close to you....
Some info, about why not try to replace the pcb:
results-the-yourself-solutions-t11912.html
Janos
PostPosted: June 12th, 2009, 17:53
:evil:
http://yura.projektas.lt/files/wd/mhdd/index.html
http://yura.projektas.lt/files/wd/mhdd/wd_royl_rom.html
http://www.elektroda.pl/rtvforum/viewto ... 48#6625648
PostPosted: June 12th, 2009, 18:14
Sorry, but i don't get it, you are on which side? :mrgreen:
On the user's side, on your side, or the other company's side, or Spildit's side, or what? :D
anyway, i have missed the link:
Janos
PostPosted: June 13th, 2009, 9:25
Agree with Janos, that kind of "steps information" could not be provide to a newbie, who doesnt understand on first what its a ATA protocol, or how does works a hard disk internally :?
How does i determine its a newbie?, by his post .
PostPosted: July 8th, 2009, 7:40
Spooky... my WD EBook has recently failed, I suspect I used the wrong power supply (20 volts) normally used for my laptop. ups... should be 12volts
So I open the case to have a look and see.
Spec:
PCB Model Number:
2061-701477-100 04P
Other Makings XT 4U05 6CS3 60003040 8043
and 2060 701477-002.
Does any one have an opinion on weather the drive could be damage, or can recommend a plan to fix or retrieve the data from it.
Looks like YOUSIF I have similar drives...
PostPosted: July 8th, 2009, 7:58
If you are from Preston, Lancashire, then contact PCIMAGE - he is a pro
and will help for fair prices.
Any different advice, to manipulate with your drive could harm your data.
PostPosted: July 8th, 2009, 8:08
umm..."PCIMAGE" Found there web site easily will review there service and perhaps arrange for them to take a look and see...Many Thanks ....TTFN
PostPosted: July 8th, 2009, 9:58
By all means send it down, I won't rip you off!! :-)
Sean
Users browsing this forum: No registered users and 283 guests
