 Post subject: ST3 500 320 AS - LED PROBLEM - 7200.11
PostPosted: July 8th, 2009, 15:13
Hi to all hddgurs,
Have this disk with the LED problem.
Fix that, with the udma, now i can have ID, DRD DSC.
But this case when i start copy (green) i just could copy 6 400 xxx sectors.
The rest it give error,
If i change to read with no CRC Control i can have some data but is not OK.
Anyone have this issue after resolving the LED problem ?
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: ST3 500 320 AS - LED PROBLEM - 7200.11
PostPosted: July 13th, 2009, 19:32
I can manage that one if U want to send it over.
PostPosted: July 21st, 2009, 13:43
Have this in the UDMA
ZeBong
" Россия еще раз"
PostPosted: July 21st, 2009, 16:49
yes i have try this:
F3 T>m0,2,2,6,0,0,0,22
Max Wr Retries = 06, Max Rd Retries = 00, Max ECC T-Level = 00, Max Certify Rewrite Retries = 0000
User Partition Format Successful - Elapsed Time 0 mins 00 secs
But is the same.
I think that the problem is with the P-list.
Something happen when resolving the LED problem.
If you know any commands to regenerate the p-list PM me.
ZeBong
" Россия еще раз"
PostPosted: July 21st, 2009, 17:16
I am not in the LAB right now.
but for see the plist i think is this:
F3 T>V
but is better to test in a different disk, for dont mess with the patient drive.
ZeBong
" Россия еще раз"
PostPosted: July 23rd, 2009, 18:45
Problem SOLVED
Thanks for helping.
ZeBong
" Россия еще раз"
PostPosted: July 24th, 2009, 9:50
U are welcome ;)
PostPosted: September 2nd, 2009, 3:56
Hi all HddGurus ,
I have a similar problem but with Seagate drive 7200.12 500 GB , it became non detectable in bios suddenly , i checked this forum and found a solution for this issue via terminal commands , followed that , and now the hard disk is accessible in bios but only first 1 -2 Gb are accessible rest are UNCR with all zeros , i checked in Disk editor and other utils ( MHDD , victoria ) everything after first 1- 2 GB is uncr .
commands used .
cleared smart
N1
cleared Glist
i4,1,22
translator regeneration
m0,2,2,0,0,0,0,22
F3 T>m0,2,2,0,0,0,0,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 00, Max Certify Rewrite Retries = 0000
Zone re-format was skipped.
If plist is damaged then Is there a way to reconstruct it via terminal commands , i know there will be swapped sectors and full data recovery is not possible but is there a way i can have a look at whatever data that is left on the drive , right now its all zeros - uncr !!
I have checked this forum and others for last 3 days and got a lot of info on this subject but its not working in my case , any help on this issue would be appreciated , if you do not want to post the commands pls pm me .
If you want me to post the output of defect list let know which one , in my case V10 gives the Plist , V4 is Glist
Cheers,
Nitin
PostPosted: September 2nd, 2009, 6:15
Did you notice that you have a 7200.12?
PostPosted: September 2nd, 2009, 6:23
Yes it is the newer firmware 7200.12 , at first i was also surprised .
PostPosted: September 2nd, 2009, 6:53
so you have the 7200.12 and also with the BUG BSY ?
Can you post the numbers that you have in the cover off the disk.
ZeBong
" Россия еще раз"
PostPosted: September 2nd, 2009, 7:17
Thanks for replying , The model no is ST3500418AS 7200.12 , the busy problem is corrected but i have now got unrc sectors filled all over the disk like your first post . Pls let me know how did you turned off CRC control as in your above post .
if i can switch off CRC control i can atleast get some data out !!
Regards,
Nitin
PostPosted: September 3rd, 2009, 5:04
Any suggestions ?
or , pls send me the links to the solutions of this issue , thread with similar issue
Is there a way to reconstruct the plist from cert logs and then use the retranslator command
If you need any more info from me pls let me know !
Cheers,
Nitin
PostPosted: September 3rd, 2009, 14:23
We can do it if u are interested.
PostPosted: September 11th, 2009, 10:13
Hi Gurus,
I got the same problem on a 7200.11.
Only the begining of the disk is readable after LED CC repair.
Please, can someone put me on the way ?
PostPosted: September 11th, 2009, 13:21
Can solve it in ITALY but have to send the drive.
PostPosted: September 11th, 2009, 19:24
Cannot share info, but I can do it for you. PM me for pricing.
Users browsing this forum: Google [Bot] and 111 guests
