 Post subject: PCB for WD800JD-75HKA1
PostPosted: July 28th, 2009, 16:33
Any help in finding the pcb or used hdd for the hdd below would be very much APPRECIATED
WD800JD-75HKA1 80GB SATA
S/N: WMAJ95522049
Date: 20 sep 2004
DCM: DSBHCTJCH
LBA: 156250000
PCB #: 2061-001251-000-AH
Thanx
 Post subject: Re: PCB for WD800JD-75HKA1
PostPosted: July 28th, 2009, 16:40
No offence, but why do you want a PCB?
What's up with the drive? Dead? Clicking? Burnt PCB?
Even if the PCB IS at fault, do you realise that another PCB WILL NOT WORK without at least the ROM information being transferred from the original?
PostPosted: July 28th, 2009, 17:01
PCB Burnt that is the reason for the pcb search.
For the donor pcb to work on the old hdd I would swap the FW chip.
That is the way to make the hdd visible in the bios.
PostPosted: July 28th, 2009, 18:23
What is the revision# on that PCB???
I have a lot of PCBs in stock for our data recovery use and some of them are over stocked. I can check...
PostPosted: July 28th, 2009, 18:27
Good, just checking as we get hundreds of noobs on here asking for a PCB to fix their drive as it's the easiest thing to change ,and they all hope that it will fix their drive when 9/10 times it won't!!! :-)
Yes, you are correct and would appear you know what you're doing.
I'll take a look in the morning to see if I have that PCB for you.
PostPosted: July 28th, 2009, 18:49
2060-001252-000 REV A
PostPosted: July 29th, 2009, 8:24
Hi, I have this working PCB for sale, pls contact my hotmail.
Eric
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: July 29th, 2009, 8:59
I have a 2061-001252-090 AC from a WD800JD-00HKA0
http://www.datasaversllc.com
PostPosted: July 31st, 2009, 13:23
I have too .
PCB #: 2061-001252-000-AH
PostPosted: July 31st, 2009, 14:16
The PCB from jono-ats shoud do the trick with a ROM transfer, plus in in U.S. too.
PostPosted: August 1st, 2009, 10:04
pcimage
Help me out here, I have asked Jono-ats and Rameez for the price of the pcb 48hrs ago so far they have both cared not to send me a message if they have a price for the said item.
Users browsing this forum: Google [Bot] and 91 guests
