 Post subject: Why you should not put HDD tech confidential Info Out on Net
PostPosted: August 25th, 2009, 4:55
http://forums.seagate.com/stx/board/mes ... d.id=11830
They put a link direct to HDDGURU forum to the RS232 command manual... I'm getting really fked 0ff with this now...
Your share, you don't care....simple as that
 Post subject: Re: Why you should not put HDD tech confidential Info Out on Net
PostPosted: August 25th, 2009, 5:37
with less easier cases coming in due to people sharing info, and easy cases which are now hard due to mistreatment of info, i'm just going to start charging double for these cases and for seized motors. I think the seized motors could be on a par with the firmware corruption in terms of failure rate. I'm seeing loads of them, like to see then sort that out with a cheap converter!
PostPosted: August 25th, 2009, 7:29
easier to be a plumber and make some real money ;o)
PostPosted: August 25th, 2009, 8:47
I think it's really odd that Seagate links to HDDGURU to provide their clients with Seagate's own info!
But it figures . . . In my experience, Seagate's factory tech support has been worse than awful.
http://www.datasaversllc.com
PostPosted: August 25th, 2009, 9:34
It's not that bad, I think - 99% of people don't know what rs232 is,
and then of the rest 50% are scared to do something and
of the rest 25% are too lazy to try it and of the rest it does not work
1/2 the time - so that leaves a few handfuls of people who would not pay anything
for the work anyway.
Anyway WD, Hitachi and sungsam are determined to outdo ST and those solutions are not so easy, so glory
days for gurus are just around the corner, once again just like 2002.
PostPosted: August 25th, 2009, 11:45
Oh yeah.
PostPosted: August 25th, 2009, 12:02
How about not posting confidential info on the forum and only answer via pm for specific details and solutions?
PostPosted: August 25th, 2009, 12:06
Im talking about Seagate being aware of this information in the public domain... Not good!
PostPosted: August 25th, 2009, 12:54
Knowing Seagate they probably wouldnt mind. Less hard drives they would have to repair or replace :) . Ah, you f**ked with firmware. You voided the warranty.
Users browsing this forum: Google [Bot] and 155 guests
