 Post subject: 7200.11 Firmware problem
PostPosted: August 31st, 2009, 4:18
Seagate ST3500620AS
Firmware HP12
Can anybody knows solution for this.
The disk is BUSY when connected.
We disconect PCB, started termina, Clear SMART, Fixed G-list
then mount back the PCB, power off/on the drive
and terminal is not available.
What can be problem, do you know what to fix
 Post subject: Re: 7200.11 Firmware problem
PostPosted: August 31st, 2009, 5:24
Try the search button.
Zero Alpha: zeroalpha.com.au
PostPosted: August 31st, 2009, 6:20
PostPosted: August 31st, 2009, 10:27
I think many people know the solution, but it is only simple if terminal is available.
Try to get into terminal again, if not then you must consult some expert near you.
PostPosted: August 31st, 2009, 11:08
I think there is a warning that you could brick your drive if you do something wrong.
www.datarecoveryne.com
PostPosted: August 31st, 2009, 14:16
@grado (and others)
the fact that a drive has certain symptoms, doesn't mean that the med to be used is the same in any case. What do you want to do now ?
Users browsing this forum: Google [Bot], Stritom and 239 guests
