 Post subject: HITACHI NOTEBOOK HEAD SWAP
PostPosted: September 18th, 2009, 18:18
Hi to all,
I am doing some research in a hitachi notebook Head Swap.
I am matching a lot almost everything but i still can not be 100% sucess with this.
In the picture i use the same model and with the same MLC, when change heads can not have ID.
Puting the heads back in the donor i can get ID.
Anyone have made this 100% sucess.
Would like to know if anyone have a good opinion in this.
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: HITACHI NOTEBOOK HEAD SWAP
PostPosted: September 19th, 2009, 5:05
Just match model, part number and MLC (but not critical) you should then have 100% success.
PostPosted: September 19th, 2009, 12:56
You've got it turned around.
These should be a match, but you'll need a 160 GB donor drive. A 120 is missing one of the heads.
Jon
http://www.datasaversllc.com
PostPosted: September 19th, 2009, 13:49
Jon
This case i had clone the head 0 1 3, just need the head 2, and i can do it witht the 120gb, but have problems ....
ZeBong
" Россия еще раз"
PostPosted: September 22nd, 2009, 16:45
some of the 120G models have 4 heads too, but I could not find how to rule it out by the MLC (I must admit I did not check many drives, only a few.)
PostPosted: September 22nd, 2009, 17:38
We do the same thing frequently, and it almost always works. Check PCB number as well - they should match.
PostPosted: September 23rd, 2009, 11:47
Thanks to all for helping :D
ZeBong
" Россия еще раз"
PostPosted: September 23rd, 2009, 13:58
What was the result? :)
PostPosted: September 23rd, 2009, 14:01
Is doing very very slow , but is going ;)
Thanks NC :)
ZeBong
" Россия еще раз"
Users browsing this forum: Google [Bot] and 71 guests
