 Post subject: MAXTOR 541DX ATHENA DSP sa error
PostPosted: November 10th, 2009, 12:03
I have the following problem, when I load the drive with loader and try to write to sa I receive an error. Should I also load the ram image from the working drive? I am not sure where the problem is, because I have no problem reading the service area. Only the G_LIST module cannot be read. And last question what can be done if there are bad sectors in sa?
 Post subject: Re: MAXTOR 541DX ATHENA DSP sa error
PostPosted: November 10th, 2009, 14:02
Most probably the problem is elsewhere and not related to SA, but assuming all the rest is ok (it's an ATHENA.... :D )... what are you using to access SA ?
PostPosted: November 10th, 2009, 15:14
OK thank you for your reply. I am using the free hddrepair. The things are quite strange. I can read every module from sa except G-LIST. I doubt there is problem with with the SRV or RCT modules. I wonder if I should load the ram also except the loader. And what happens if I have bad sectors in sa, can I do something to remap these sectors.
PostPosted: November 10th, 2009, 15:53
Basically RAM is not needed. But instead U might be using the wrong loader...
PostPosted: November 10th, 2009, 16:05
Hmm so the wrong loader will read the modules correctly?
PostPosted: November 10th, 2009, 16:11
Your problem is HDDREPAIR :mrgreen:
PostPosted: November 10th, 2009, 16:43
I hoped that hddrepair is my cheap sollution :wink: but thanks anyway. It seem if I cannot write to sa it is not possible to repair this old maxtor. Well at least I will get two neodymium magnets :shock: .
PostPosted: November 10th, 2009, 18:18
The cheap solution would be this:
http://wareseeker.com/download/hdd-firmware-repairer-2.0.rar/58245
Maybe this is called cheating! :lol:
PostPosted: November 11th, 2009, 13:16
Hey dick, thanks for the link. I downloaded the proggy from their site: http://www.salvationdata.com/data-recovery-freewares/maxtor-firmware-c.htm. And what a strange coincidence I have the exactly same model they are refering Maxtor 541DX (2B020H1 2B010H1). I booted from the floppy unpatiently and tried to repair the hdd. I have to admit they have made really simple "one click" GUI. When I tabbed on "Repair Now" button the proggy displayd something like:
table1 error....repaired
table2 error....repaired
table3 error....repaired
(ain't that simple :wink: )
with nice red letters. But what a suprise when I restarted the pc the drive didn't start. I tried the procedure a couple of times but it didn't help and only displayed the same result. I guess there is something wrong with the adaptives after all. Any more suggestions are welcomed.
PostPosted: November 11th, 2009, 17:06
Didn't you say that there were bad UBAs ? How do you expect that simple program to work ? :mrgreen:
PostPosted: November 12th, 2009, 4:16
I think it is time for asking for a pro here...
Users browsing this forum: No registered users and 107 guests
