 Post subject: Hitachi HTS541616J9SA00 NVRAM error
PostPosted: November 17th, 2009, 23:21
Hi all,
The drive clicking, I verified that PCB's good. My client said that they "deal with pirate Chinese tool" and make NVRAM error.
Any ideas?
Thank you.
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
 Post subject: Re: Hitachi HTS541616J9SA00 NVRAM error
PostPosted: November 18th, 2009, 3:36
with a working board the drive should stop clicking, at least if its heads are fine. Check that first.
If it is not clickin, u will have to search for the SA, read modules and rebuild the original NVRAM (hint: the adaptives are mostly logged in FLOG)
PostPosted: November 18th, 2009, 4:26
Thanks pepe for your hint.
The drive still busy, can not get ready, clicking non stop. I swap PCB of a good drive, it can get ready with 2 red led.
PostPosted: November 18th, 2009, 5:14
I get more and more of these with damaged surface. Can you check the heads under a microscope to see if they are not damaged?
Dobre
Murphy was an optimist
PostPosted: November 18th, 2009, 5:43
Thanks dobrevjetser, I'll check.
But I don't think the head is damage, only NVRAM.
PostPosted: November 18th, 2009, 5:53
Well, very well possible, but i've lost allready much time on these drives thinking it was a SA or nvram problem when it turned out to be bad heads or surface damage :(
Dobre
PostPosted: November 18th, 2009, 6:00
Thank you, I'll give it a try
PostPosted: November 18th, 2009, 13:33
I have noticed many with surface damage as well
(hint): the surface damage may not show itself at first glance, sometimes a closer look is needed.
PostPosted: November 19th, 2009, 3:18
Thanks Russwinters!
Users browsing this forum: Bing [Bot], Google [Bot] and 341 guests
