 Post subject: Drive PCB Without ROM submitted
PostPosted: December 21st, 2009, 15:39
any idea?
7200.10 drive from client, without the ROM in PCB...
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Drive PCB Without ROM submitted
PostPosted: December 21st, 2009, 17:00
I won't be surprised if there some other issues with a drive besides a ROM chip.
www.datarecoveryne.com
PostPosted: December 22nd, 2009, 3:55
the ROM CHIP was removed already from the PCB while client submitted the drive.
__________
THANK YOU
SHAHI
PostPosted: December 22nd, 2009, 4:12
The ROM on 7200.10 does not contain adaptives unique to the drive, so matching compatible ROM will allow for compatibility. If you can not get original ROM, I would start by trying to find donor PCB with matching code eg. 100406541. Alternatively if you have large collection of ROM resources for 7200.10 you can try several to try find a match.
You will need to verify compatibility via Terminal output as I have a feeling there may be other problems also :(
PostPosted: December 22nd, 2009, 18:16
Am I wrong thinking that SA location varies on .10 and it is hardcoded in the ROM?
PostPosted: December 23rd, 2009, 4:44
Maybe you are right, I am not totally sure. I have had some success in PCB replacement without ROM soldering, but also some cases where ROM transfer is needed. Maybe with .10 it is possible to simply get lucky :)
PostPosted: December 23rd, 2009, 4:49
you have to be very lucky if SA location is the same but it is possible, I've had some success with Travelstars without changing ROM. (1 out of 300!)
PostPosted: December 23rd, 2009, 4:53
Were your hands sore after changing 300 PCBs :lol:
PostPosted: December 23rd, 2009, 4:54
Ok, I should have mentioned over the course of a few years. lol.
PostPosted: December 23rd, 2009, 6:54
I've made interesting experiences with seagate drives in the past. I didn't understand why SA location changed after a selfscan. In fact tracks change but gray code always seems to be the same. Reading the rom after the selfscan showed no differences... In drives with the same firmware revision, gray codes seems to be constant but, tracks are different and pcb swap is possible without swapping rom. But these drives were not .10
PostPosted: December 23rd, 2009, 7:43
thx all for cooperation, i will let you know updates
__________
THANK YOU
SHAHI
Users browsing this forum: Google [Bot], Lukas and 244 guests
