 Post subject: My HITACHI is dead...
PostPosted: February 13th, 2010, 10:38
Hello people!!!
I was trying to connect my SATA Hitachi HDP725025GLA380 using the IDE to SATA cord, i did it wrong and now it`s not working. My question is: what is that part, or where can I find the schematicas of my drive?
http://www.imagecross.com/11/image-host ... 010816.jpg
 Post subject: Re: My HITACHI is dead...
PostPosted: February 14th, 2010, 17:47
The part looks like a 5V TVS (transient voltage suppression) diode. You can replace it with an SMAJ5.0A from Farnell, Mouser, Digikey.
Alternatively, if you can trust your PSU, then you can desolder this diode or cut it out with side cutters. The drive will run quite happily without it, albeit without protection on the affected supply rail.
Here is a pinout of the SATA power connector:
http://pinouts.ru/Power/sata-power_pinout.shtml
Sometimes there is a fuse associated with the TVS diode, but I don't recognise any.
BTW, I'm not a DR professional, just an observer.
PostPosted: February 14th, 2010, 18:32
Anyway, you are right.
But i need to add:
If the diode is exploded, like this way, there can be more damage in the PCB.
It is a good idea, to do some more measurement like checking shorts in the pcb's power components including VCD chip.
Preamp checking also a good idea in this case...
Janos
PostPosted: February 15th, 2010, 1:57
change diode and check.
data recovery service[/b]
Users browsing this forum: Majestic-12 [Bot] and 78 guests
