 Post subject: MAXTOR N40P GURU NEED HELP
PostPosted: March 13th, 2010, 15:41
MAxtor 6E40LO
Serial E11QWEN
Firmware NAR61HA0
Problems:
I testetd SA with PC3K Udma the conclusion its:
Modules | Comment
95 | HDD has errors not critical for its normal operation. But before
| copying user data you should switch off automatic adding of defects to
| the defect-list.
>Read roadmap............................ : Ok
>Read roadmap extension.................. : Ok
>Read zone allocation table.............. : Ok
>Read Technological ID................... : Ok
>Read Zone allocation table extension.... : Ok
>SA head................................. : 3
>Ext Model............................... : 6E040L0711214C
>HDD has an alternate service area
I have testet SA writing test its OK
Problems:
the hdd its not recognized by bios
Not have acces to user data
At the xp utility mount the disk may Read/write operation count remain 0
Can you help????????????????
 Post subject: Re: MAXTOR N40P GURU NEED HELP
PostPosted: March 13th, 2010, 16:10
Can you attach the whole SA including groups on encrypted RAR or ZIP and PM the password ? (just for privacy)
If you start drive with loader, does it start or have problems i.e. late calibration ?
Checked the error lists (for trashed entries) and translator ;) ?
PostPosted: March 13th, 2010, 16:51
I vote for MBR problem only. :D
This drive should apper in BIOS, i am sure.
J
PostPosted: March 14th, 2010, 4:05
If all modules are OK drive should detect and one more thing what model does it show in Pc3k.
PostPosted: March 15th, 2010, 16:04
Tank you for your suggestions, really has been damaged MBR.
I solved the problem with WinHex
PostPosted: March 15th, 2010, 20:24
good job.
data recovery service[/b]
PostPosted: March 15th, 2010, 20:32
networkpc3000 wrote:
good job.
Thank you :mrgreen:
Users browsing this forum: kotel, Majestic-12 [Bot] and 58 guests
