 Post subject: Hard Drive with built in USB problems
PostPosted: March 26th, 2010, 9:33
Are the drives with built on USB connections causing problems for use of tools such as DDI, PC3000, etc? Or have you found a way around (not asking for the method used, just if you have) the issue?
 Post subject: Re: Hard Drive with built in USB problems
PostPosted: March 26th, 2010, 10:12
If you're talking about WD 2.5" it can be "converted" to sata
PostPosted: March 26th, 2010, 11:04
The only theory I had was using a compatable board from a drive that didn't have the build on connection,, also there are quite a few pins on the drives with built on USB, thought some of them may be sata data connection, but haven't had enough time to check it out, no real need, currently do not have DDI or PC3000.
PostPosted: March 26th, 2010, 14:10
The PCB can be modified to use as a SATA
Iorana Haraharaini
PostPosted: March 26th, 2010, 14:18
Figured as much, knew there was somthing to all the pins, Thanks for the info guys
PostPosted: March 26th, 2010, 14:36
I remember when we got our first one in. Think it was a WDXXXXBEMU. Thought "Right now just to remove the USB adapter and.....oh.....well thats bloody awkward!" :)
Leigh
DataWreck Data Recovery Services
www.DataWreck.co.uk
PostPosted: March 26th, 2010, 14:39
Yeah between that and the 256-bit hardware AES enclosures WD has made some pretty lame design decisions lately.
PostPosted: March 26th, 2010, 20:04
like WD passport and Samsung portable drive? 8)
data recovery service[/b]
PostPosted: March 26th, 2010, 20:17
Exactly, have not run into a Samsung one yet, but have run into a Samsung with a TINY PCB, PM if needed, does Samsung have the same bypass?
Users browsing this forum: No registered users and 269 guests
