 Post subject: How to repair ?
PostPosted: May 19th, 2015, 6:44
i have seagate 1000 gb FreePlay ST1000LM010 i attach the log file on linux .. there is a way to understand if is logic board or mechanical dead? thank you!
hd.txt [51.24 KiB]
Downloaded 540 times
 Post subject: Re: How to repair ?
PostPosted: May 19th, 2015, 13:45
[280056.885428] end_request: I/O error, dev sdb, sector 4
[280056.885435] Buffer I/O error on device sdb, logical block 1
It's a mechanical problem: bad blocks / media damage / weak heads. If drive spins and you get a error log your pcb is fine.
PostPosted: May 22nd, 2015, 15:56
Well,
Best idea is to hook to terminal and see the data output
PostPosted: May 22nd, 2015, 16:04
It's not a PCB issue, as already mentioned.
If the data is important then seek pro assistance, but if it's not worth spending any money and assume the DIY risks then you can try cloning with a non-windows sector cloner such as dd_rescue or media tools pro. Then scan the resultant clone with recovery software such as rstudio or getdataback.
****DIY COMES WITH RISK TO DATA****
PostPosted: May 22nd, 2015, 16:40
Well,
i do not have any experience with ddrescue yet but pmt you can use ctrl-s and set retry counts to 0 :mrgreen:
PostPosted: May 22nd, 2015, 17:59
Spildit wrote:
Amarbir wrote:
Well,
What ? :shock: :shock: :shock:
Well,
Are You Shocked That i do not use ddresque or you did not understand what i said about PMT .PMT = Prosoft Media Tools
PostPosted: May 22nd, 2015, 18:14
Spildit wrote:
Amarbir wrote:
Spildit wrote:
Amarbir wrote:
Well,
Well,
Sorry my bad.
Because on the other post you were talking about TTL terminal i assumed that you were saying for the OP to use something like CTRL+S on the terminal ...
I didn't realize you were talking about Prosoft Media tools.
In any case if this was my drive i would check with terminal first, then disable relocation and then attempt to clone with hardware.
Well,
This will happen when one of us you and me included will not read a thread or post properly .You are excused your highness ,But i like you stepping on my tail adds horsepower learning capability lol
Users browsing this forum: No registered users and 136 guests
