 Post subject: Intenso 256GB - dead
PostPosted: November 19th, 2026, 11:11
Hello forum,
let me introduce myself briefly, i am an electronic engineer from Germany and htis is my first encounter with SSD failures.
So i dont know about PC3000 or SMI MP-Tool .
I had this Intenso 256gig SSD drive plugged into USB via USB-Adapter and last action was to erase a bigger file.
I then just pulled it out of the USB port of the Windows PC.
Later re-inserting it - and - nothing. No Drive Letter appeared. It was non existend. completely dead.
I had some important files on it.
Ok, i searched the forums, reading about ROM mode, flash chip identification, PC3000 rescue software and the SMI tools.
I checked the Voltages, 3.3V, 1.2V and 0.9V, all good.
There are 3 LEDs og which the middle LED was constantly on, indicationg ? Power?
Then there are these jumper connectors, 2 upper, 4 lower.
I guess the top one is for ROM mode, the others are ??? what?
ROM mode is when the sm2259 controller enters a service mode ?
What can you then read out of it ?
ched some light in my empty brain ;)
 Post subject: Re: Intenso 256GB - dead
PostPosted: November 19th, 2026, 12:17
Did the SSD identify itself in ROM mode?
For reference ...
BL8028, Shanghai Belling, Synchronous Buck Converter, 1.5A, 2MHz, 2.6V - 5.5V in, marking GUyw, SOT23-5:
https://www.belling.com.cn/media/file_object/bel_product/BL8028/datasheet/BL8028_V1.13_en.pdf
PostPosted: November 20th, 2026, 8:56
I do not know howto enter ROM-mode.
Do you know which jumpers i have to short to enter it? ( see foto)
What are all the other 4 jumper/connector-holes for?
If in ROM-mode, PC will see what?
PostPosted: November 20th, 2026, 9:23
Sorry, i just tryd it with the upper jumper and it worked.
ROM.png = Devicemanager Ankeje USB3.0 SCSI Disk
diskman.png = Storage management, new Disk_1 , 1GB, not initialized
OK
PostPosted: November 20th, 2026, 9:53
That means that the SM2259XT controller has basic sanity, which in turn suggests that the SSD has a firmware problem, probably due to bad NAND.
PostPosted: November 21st, 2026, 6:26
yeah,then tried to read the flash IDs using smi_flash_id_usb.exe.
No luck,
v0.569a
OS: 10.0 build 19045
Drive: 1
Model: ANKEJE USB3.0
Fw : 4101
Controller : SM2259XA (SM2259XT2) bufferless
seems the ANKEJE USB3.0 SCSI adapter is not working with the smi_flash_id_usb.exe program.
Will now try it on a real sata port.
PostPosted: November 22nd, 2026, 15:04
hmm, why do you think the Nand chips are bad ?
PostPosted: November 22nd, 2026, 15:07
I mean that the Flash Translation Table is probably corrupt due to NAND read errors. That's typically what happens.
PostPosted: Yesterday, 5:55
NAND read errors
Ok, that sounds like a hardware problem.
Funny though, i am unable to read the Nand chip IDs with the smi_sd_flash_id or smi_flash_id_usb or smi_flash_id_ata Tools
from here:
http://vlo.name:3000/ssdtool/
i now have the ssd connected to a real sata port in an old PC, still no luck.
might do another "bad capacitor test" on the board.
PostPosted: Yesterday, 10:36
hotspot wrote:
NAND read errors
from here:
People here would deem it a "hardware" problem if any NAND IC were completely dead. Otherwise, as long as the NAND IDs can still be read, then it's a "firmware" problem. I agree that technically it's a hardware fault in both cases, though.
PostPosted: Yesterday, 13:46
:D
just wondering...
The Nand-Chip marking H8A1B-2112A, that is not an official marking code, rather some ??
2112 could be the date 2021 in december.
But H8A1B ?
The chips look grinded of the original marking.
PostPosted: Yesterday, 13:54
I'm guessing it's house-marked SK hynix flash. There is a 2209 (YYWW) date code on the PCB ...
PostPosted: Today, 7:58
Ok Ok ;)
finally...it works reading the NAND IDs.
From Vlo's smi_flash_id-readme.txt translated from russian, it says:
For the ATA version:
- It only works when the disk is connected via an ATA controller using drivers such as those from
Microsoft (pciide, msahci, storahci) or Intel RST.
so i changed over to another PC, installed winxp with no hardware specific drivers for the motherboard.
verifying the driver for the dual channel pci ide controller is pciide.sys from microsoft.
Connecting the SSD with the ROM-bridge connected and it appears as a 1gig drive.
Then running smi_flash_id_ata.exe results in the following output:
v0.569a
Drive: 1(ATA)
OS: 5.1 build 2600 Service Pack 3
Model: SM59XT2A-80-10000001
Fw : 20210308
Size : 0 MB [0.0 GB]
Controller : SM2259XA (SM2259XT2) in ROM Mode
Bank00: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
Bank01: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
Bank04: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
Bank05: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
from here we might be able to restore the SSD using SM-Flashtool.
If we can recover the data, i am not realy sure ;)
PostPosted: Today, 8:58
100% of your data will be lost. SSD recovery and data recovery vary greatly in complexity and cost. Some SSDs are impossible to recover data, even with DR Pro.
Users browsing this forum: No registered users and 93 guests
