Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: Seagate ST3500320AS unable to jump to terminal
PostPosted: August 8th, 2008, 2:40
I have seagate ST3500320AS unable to jump to terminal (yes i have tried setting baud rate to 38400 and Cntrl-Z), this drive is transition between Maxtor to Seagate. Inital startup drive is struggling and few noise not exactly clicking, unable to detect in PC3000 UDMA.
Any idea guys, thank you so much.
 Post subject: Re: Seagate ST3500320AS unable to jump to terminal
PostPosted: August 8th, 2008, 4:17
Can you access terminal with the pcb off the hard drive?
PostPosted: August 8th, 2008, 5:39
hi dell, no
PostPosted: August 8th, 2008, 7:58
ST3500320AS - 7200.11
BaudRate=38400 [38400,No,8,1]
Online commands:
Ctrl+A, Ctrl+L -> (PCB+HDA or PCB only!)
Ctrl+U ... -> (PCB+HDA)
ROM is 512kB, and many informations are stored in ROM...
Mikippp
RequestResumeSaveSmartFrame
F3 T> [Ctrl+Z]
F3 T> [Ctrl+A]
Package Version: MS0100.SDD2.AD090B.SD25    , Package P/N: 100504083, Package Builder ID: 3K,
Package Build Date: 01/16/2008, Package Build Time: 16:26:59, Package CFW Version: MS01.SDD2.00052452.3K00,
Package SFW1 Version: B000, Package SFW2 Version: C0FE, Package SFW3 Version: C0FA, Package SFW4 Version: ----
Controller FW Rev: 01161626, CustomerRel: SD25, Changelist: 00052452, ProdType: MS01.SDD2, Date: 01/16/2008, Time: 162659, UserId: 00000761
Servo FW Rev: C0FE
RAP Format Rev: 0092, Contents Rev: 15 05 10 06
F3 T> [Ctrl+L]
TetonST 2.0 SATA Moose Gen 3.0 (RAP fmt 10 ) w/sdff (RV )
F3 T> [.]
Current R/W User LBA 00000000 LLL CHS 000000.0.0000 PLP CHS 000000.0.0000
R/W Status 1 R/W Error 00000080 Ready
F3 T> [;]
This command is no longer supported.
Use the Online Control-L command instead.
PostPosted: August 8th, 2008, 10:01
Bad SA so the weird noise ? Is that noise similar to "white noise" , like a hiss ?
PostPosted: August 8th, 2008, 10:35
thanks Mikippp, BlackST ,it sounds like the heads are trying to calibrate and making very faint clicks then DRY and DSC but unable to id.
PostPosted: August 8th, 2008, 14:25
Is sa full ok? How can it go rdy with bad sa?
PostPosted: August 8th, 2008, 21:59
hi BlackST , that puzzled me too, it goes RDY but unable to check anything.
PostPosted: August 8th, 2008, 22:02
most of the terminal command in 7200.11 are changed.
i have found some clues but still working on it.
DF :)
DF :)
www.datatracksystem.net
PostPosted: August 8th, 2008, 22:53
Hi TerraNova,
I think you have ROM corruption!
I have exp. same problem few weeks ago.
PostPosted: August 8th, 2008, 23:27
quasimodo wrote:
Hi TerraNova,
There are two incompatible things: ROM corruption and 7200.11 drive in ready state :)
That's definitely not ROM corruption I would say it's heads or motor problem
hi quasimodo, i will check it out thanks, if it is corrupted what do i do? find identical rom?
PostPosted: August 8th, 2008, 23:32
TerraNova wrote:
find identical rom?
good luck with that. I have serious doubt in that probability :)
PostPosted: August 8th, 2008, 23:41
Doomer,
I can uderstand why you are saying It could be weak heads, but why do you think it's motor?
PostPosted: August 8th, 2008, 23:49
TerraNova,
I can only speak for my case, Doomer is certainly more experienced then I am, and the problem could of course always be something else like heads.
Recently I was experimenting with allot of different drives and created allot of defects and malfunctions for testing purposes. With this drive I edited ROM content. I only changed 4 or 6 bytes and the symptoms that you are experiencing are exactly the same ones that I had after corrupting the ROM.
After I restored the original data to the ROM it worked perfectly again.
Therefore I gave my above comment.
PostPosted: August 9th, 2008, 13:46
quasimodo wrote:
Doomer,
There were some drives exactly ST3500320AS model and they had motor problems, sound was as described in this topic
PostPosted: August 9th, 2008, 14:54
@doomer, please explain : motor problems mean motor running with noise or unstable bearing so platter vibration ? (Just curious, don't have many seagates here and the ones around seem not to fail more than expected)
PostPosted: August 10th, 2008, 0:07
I beleive it's both, as I remeber it was necessary to make platter transplant
In this particular case I would start with heads checking to understand the condition of original heads
Bad thing is such drives is pain in the ass concerning heads xplant :(
PostPosted: August 10th, 2008, 0:27
Thank you all for participating in this,
Hi Doomer how to check the head if no access to terminal? SWAG? Simply Wild Ass Guess? :D FYI the drive is not vibrating violently, it is normal, so i assumed motor problem is eliminated, i have inspected the top platter no problem, i even looked at the magnetic heads under scope and they looked good no obvious sign of scatches.
Quasimodo, how do you alter the ROM? manually download using rom reader and edit it? or using pc3000? I cant even access ROM using pc3000.
Thanks all.
PostPosted: August 10th, 2008, 1:40
check pm :D
Users browsing this forum: No registered users and 223 guests
